Explorer 8.8 disc brake swap
Maverick
FoMoCo MoFo
17
Eureka, California
I have both a drum and disc brake Explorer 8.8's laying around. What's involved in swapping the disc brake set up to the drum brake housing? Is it as easy as removing the drum hardware and backing plate and replacing it with the disc components? Or is there differences in the housing or axle shafts? If I had both of them available to look at and tear down I wouldn't be asking this question, but my disc brake 8.8 is buried in storage.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
They are the same housing and shafts....swap away.
4.0B2
151
Walls, MS
4.0 v6
yep very simple. i did this b/c the disc brake housing was slightly bent.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I thought I read somewhere the centering pilot on the axle flange was a different size on some years. Though if so, it'd only be a matter of switching the shafts.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I know the pilot on the 28 spline is smaller than the 31 spline.
My 28 spline drums would not fit on the 31 spline shafts.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
what about master cylinders? thought i read somewhere they needed to be swapped as well
mhughes165
9
302
master cylinder swap is not needed, stops just fine as is, infact my b2 will put me through the windshield if i stab on the brakes lol
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
sweeeeeeeeet.....i wasnt gonna convert mine b/c i thought i needed a new MC
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Maybe that's what it was then (or someone confusing the 28 spline stuff with Ex axles)
As for the MC, I didn't change mine either when I put a '99 Ex axle in mine. Seems to be fine, no issues.
I've read reports if you don't have rear ABS, then you might need to swap the MC, though I have no personal experience with non-RABS trucks.
mhughes165
9
302
ya, come to think of it i dont think ive owned a pre 87 rbv so they all have had rabs, maybe someone without rabs has a idea
