Engine ticking
golley
24
do you have any oil leaks at the head? especially the cam end seals. that can cause the the nearest valve assembly to the leak to not oil right even if it it gets oil.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
When the ticking stops you have to run - I saw it in the movies.
It's usually best to run before there ticking stops.
golley
24
playlist...
"..come on Mary, don't fear the Ticker.."
- Blue Oval Cult
"..you tok too much, you worry me to death.."
- Ranger Redding
i thik ma brain swole from da heat
snoranger
Professional money waster
ASE Certified Tech
13,678
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
playlist...
- Blue Oval Cult
- Ranger Redding
OK... Now you go stand in the corner for 10 minutes and think about what you just did!!!
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
playlist...
- Blue Oval Cult
- Ranger Redding
golley
24
Yez sir, corner secured. thank the lord btw finally made it out of the shop; it just hit 99 degrees here.
rusty ol ranger
2.9 Mafia-Don
7,593
Michigan
177 CID
You know....
Exhaust leaks can tick too....
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
Maybe it has Tourette's Syndrome.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
There's nothing funny about tourettes syndrome. STINKY HOT DOG FART!
sheep herder
1,024
sheep pen
If it ain't broke, break it.
That wasn't a hot dog. Or a fart.
gaz
671
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Gabe03:
Rusty o Ranger makes a good point
You should consider adjusting your rockers. 80k is plenty of time to need an adjustment. Caution, the 2.9L uses hydraulic lifters so the adjustment needs to be made with the resulting correct preload on the lifters.
While you have the rocker arms off, it is highly recommended that you thouroghly clean the inside of the arm assemblies. Inspect your push rods for wear too.
[recommend moving to 2.9L forum]
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,513
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Moved to the 2.9L forum...
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
I have it. It gets pretty silly sometimes. I don't randomely cuss but I have a barely noticeable twitch where a give my head a little shake. But sometimes it looks like I have bugs on my face and im trying to shake them off.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
cam bearing wear
