electrical gremlin
wildbill8135
I recently decided to rewire my speakers because no set of speakers i put in the ranger were working properly. The original setup was custom and had all left side speakers wired together and all right side speakers together. I split them up and now i have no radio and no windshield wipers. It is most likely a loose ground. what would be the best way to trace a loose ground?:damnit1:
kimcrwbr1
46
maplevalley WA
2.8l
Are the wipers and radio on the same fuse it depends on the radio if none of the speaker wires are shorted the sterio should have a wiring diagram find the ground wire and ground it to the chassis or any good metal some have multiple grounds assure your getting power not alot there as far as wiring did you get the polarity right on the speakers is real important also. Is your antenna hooked up
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
Check to make sure you didn't pop a fuse in the process. I've been caught by that a couple times now when I've done stereo work. Get it all together and sure it's right but nothing works... panic sets in for a brief moment and then you remember to check fuses.
When I've wired up stereos in my trucks, I've often run a ground straight back to the battery for the radio and for any amps. Overkill? Perhaps. But I've had ground problems before and take no chances anymore. Fried a $500 amp once because I had it grounded to the body and a bodyshop fixing another part of the truck removed the wire (why, I'm still not sure, there was no reason) and attached it somewhere else. With a wire straight back to the battery, it leaves little to chance.
