Yotaismygame
- Oct 15, 2020
- Reaction score
- 196
- Location
- Oregon
- Make / Model
- Splash 2wd
- Manual
I will be running a stand alone ecu and I would like to bypass the key switch and just turn the truck on with a toggle switch. I will only need it to power the interior functions and exterior lights. Everything else will be ran through the stand alone.
Also I modified my steering column to except an electric power steering motor. While doing that I damaged the ignition while taking out the lock mechanism. When I attach a battery to the truck everything is already on key in or out. Where can I tap in to control the truck with just a toggle switch?
