Bronco II explorer questions?
BishNasty
Hi guys,
I have a stock 5spd 87 bronco II. I'm looking to lift the truck so I want stronger axles, I found a 92 parts explorer for a couple hundred bucks. its got about 200k on it with a rebuilt 4.0 auto trans.
Now my questions are will I be able to use both front and rear axles from the explorer on the bronco? I'm prettty sure its a ttb dana35 in the front I'm not sure what's in the rear. Also will I have any issues with lifting the truck after I do the axle swap? Lastly I was wondering if I wanted to possibly do the 4.0 swap at some point, would it be better to use the one out of the explorer and find a manual trans or just wait till I want to do the swap and go get one from the junk yard with a manual trans?
Anything helps.
Thanks
b2rich
Lake Oswego, OR
whats an engine?
Hi guys,
Anything helps.
Thanks
if you use the search feature, you will see that there are dozens of topics on this. Also the techsec has a shitload of info.
you will also see that you dont need to do stronger axles just to do a lift.
BishNasty
Okay I'm new to this. I know I don't really need stronger axles but I want to put bigger tires as well.
The thing is with the Dana 28 its like my tires are a "V" shape and its wearing out my tires. Will I have the same problem wither Dana 35?
Thanks again.
b2rich
Lake Oswego, OR
whats an engine?
alignments do wonders. however; some say that if you go with a mild 2" lift, all you will need is an alingment. I went with new superlift 132s on the front and exploder springs in the rear, still needed to have a radius arm bushing changed out to adjust for the angle.
alot of the guys just do adjustable camber bushings. i tried them, didnt do squat.
if i had to do it all over again, i would of followed the suggestion of many of the peeps on here and just gone with a 4" lift kit that included everything, and called it good.
http://www.jamesoaksenterprises.com/products/skyjacker-b2.htm
Which might still happen.
just my .02 and i could be wrong.:D
