- Sep 27, 2016
- 136
- 2000 Supercab
- Stepside
- Engine Type
- V8
- Engine Size
- 5.0L GT40
- 2WD / 4WD
- 2WD
I do understand all the downfalls, I've had a few modified 302's over the years. But yes, it will also have twisted wedge cnc heads, cam, injectors, and locally tuned. Power nor performance is not something I care about with this truck as it is built just to be a properly bagged cruiser with a good stereo, the engine swap is just for the sake of Looks and Sound. If I need to try restrictor plates inside the piping or tapered spacer I will address that at the time, as well as if my tuner wants to move to Haltech instead of SCT to have better throttle tip-in control then we will go that route.Are you staying with stock heads? Going with forced induction?
The only reason I ask is because that 80mm throttle body is far too large for a stock engine. It'll definitely remove a lot of throttle response from idle.. Unless you're swapping heads/intake or plan on running a power adder.
No turbo or SC, as I already have cars that are actually fast and if I wanted power and response from this truck I wouldn't waste my time with any v8 and would have just put a 2J in it which is what I normally do, and is why I have extra throttle bodies laying around, at least I'm not trying to use this Wilson 105mm..
