98+ 4wd vs 2wd Transmission Crossmember
Dave18
39
Littleton, Colorado
Hi everybody,
Are the transmission crossmembers different between 4wd and 2wd for a 2002? I have the M5OD. If so, how hard is it to weld/bolt on the 4wd version?
I've got the 4x4 transmission and transfer case sitting in my garage ready for the swap, and I'm trying to make sure I have everything before I start disassembling.
Thanks!
Transmission crossmember is the same. Engine crossmember is different, front suspension is different, the mountings for the axle are not there. Unless you have an Edge.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
do you have coils or torsion bars ?
will the swap be short-long-arm, or full front axle?
Dave18
39
Littleton, Colorado
Sweet, that is a relief. I had measured the best I could under the truck (with a loose 4wd extension housing) and it looked the same but I wasn't sure. I have the torsion bar suspension (dual sport/edge) so that should simplify the front-end part of the swap... But honestly what I found I need the most off road is low range. Phase 1 is just to get the transfer case mounted in with the new trans to achieve that. Eventually the plan is to mount a regular old SLA axle up front...
Thank you guys very much!
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
sounds like a good plan. manual shift transfer case?
Dave18
39
Littleton, Colorado
Yep! I finally found the linkage and everything. This is a project I've been waiting to try for almost ten years haha. And asking people on this forum for advice for about that long too! It's been very helpful!
