Mark_88
- Aug 11, 2007
- Reaction score
- 240
- Age
- 68
- Location
- Ontario, Canada
- Make / Model
- Dordge
- Engine Size
- 3.3 Fuel Injected
- Automatic
- My credo
- Love Thy Neighbor
The crud in the air inlet and no filter reminds me of when I first bought my Sidekick...I drove it to work happy as a clam but noticed it was using way too much fuel...the air filter had a slick of grease...not accumulated road grit over years of driving, but an actual stick your hand in the grease can and slather it on the air filter coating.
I couldn't believe it...but I replaced the air filter and the fuel consumption was fine...
I wouldn't be able to say that this caused your problem...it certainly could have compounded things...and having your battery go dead flat and not start would also...but the issue is...if I am following along...the hesitation is still there.
And this seems to only happen when accelerating...idle is smooth and otherwise no jitters...
So...again...hesitation...rather than going through the explanation myself...and mostly because I can't remember half this stuff when needed...I found this bit of reading that might help you...
http://www.aa1car.com/library/problem_hesitation.htm
It's basic but it might trigger something in your mind that might help...but still sounds like possible fuel delivery or maybe electrical problems with wires to appropriate sensors...
