91 2.3 timing belt trouble
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
ok sweet then. I wont worry about what position it is in. and with the crank sensor, i need to now replace that right? what are my symptoms of that being broken? and what are the symptoms of my crankshaft being 180 degrees opposite? i think im down to those last few problems.
oh and do i need to replace coolant before i try to start the first time? or can I test it for a few seconds and then add once i know it will start? i have no coolant in the engine at the moment.
sorry for all the questions, I just want to know this stuff before I ruin my engine.
The engine won't start with a broken crank sensor. There will be no spark and/or no injector pulse depending on which magnet was broken off
If the cam/crank relationship was 180* out of time you would have a no start/no compression, the engine would sound funny when cranking.
The engine can be run for a short time with no coolant, but should only be run long enough to verify it runs normally.
When you get a new crank sensor, make sure it comes with the alignment tool or you risk breaking the new sensor on start up. The crankshaft hub needs installed with the pulley removed for access.
And lastly.... don't worry about ruining the engine. 2.3L's are non-interference so if you get the cam timing off it won't be damaged
RedRyder97
SW Michigan
2.3 3;73 rear end 22mpg
Timeing Belt 2.3
I feel your pain ..... Wrong marks lined up on mine . I think their called manufacture marks but look really close to the timing marks . I have pictures in my photo section . Mines a 97 2.3 . The first time I really thought I messed it up . I even checked compression . And not even a pound . Valves were way off on timing. So had to tear it apart . I can tell ya once you have it on right . It makes a world of different`s on how well it runs .
Give that knuckle head of a friend of your`s the bent wrench on the head :shok:
Its constant pressure that will get the nut loose. :icon_thumby:
Dprocks100
Salt Lake Utah
2.3
Hey so autozone wants $120 for that crank sensor. I dont want to pay that. Other than the same gen and size ranger, what other years and models can i pull one from? Are mustangs the same engine?
Dprocks100
Salt Lake Utah
2.3
Seriously! My truck isnt even worth that haha im just going to go to pick and pull tomorrow and get one. But 2gen rangers with the 2.3 are hard to find here. Thats why i need to see what other vehicles use the same engine.
4b316
4
Any of the 2.3 from 89-94 will work,a mustang will work also_Or a T bird.
97rangerxlt23
Ford/Ford/Ford
2.3L/2.3L/2.3L
I've never had that much trouble with my ranger or my four banger stang.... Always sprayed it good let it soak and take a chunk or brass rod and hit it to shock it a bit and break up and rust inside there.. Then it should tap right off
Dprocks100
Salt Lake Utah
2.3
so update, changed the belt last Saturday, I superglued the sensor back together for a temporary fix (gotta love that stuff), and started it finally! happiest moment of my life haha. flushed out the radiator while I had it off with the garden hose, filled with coolant, and everything has been fine since. Thanks for your guys help on this!
TexasDuck66
July Truck of The Month
25th Anniversary Merch
