I'm a little late to the show, but welcome to the SuperDuty club. I acquired a 2000 model F-250 7.3L 4x4 from my dad a few years ago.
Can't give many details, but yeah. I was an aircraft mechanic for 18 years and already knew getting parts is bad. Moved into management side of the house last years in a training program, by first year is parts ordering and, from what I've seen so far, it's amazing that we are able to get any parts. Costs are exorbitant, shipping times are excessive, availability is rediclous.
I'm going to assume that your situation is a little different than
@snoranger,
@sgtsandman, and myself. I and atleast one of those two work on aircraft, so going to the store and buying parts isn't exactly an option. With the planes we work on we can't really go to an aircraft speciality store either. Even the consumable supply (rags, gloves, etc) side had special guidelines for procurement. Government entities, especially at this level, are stupid and ineffecient.
Run the same in mine, but not the hotshot. After doing a lot of reading I've become convinced that 7.3L don't suffer from stiction due to the injector design. Not saying that it the addative can't carry other noticable benefits, just that stiction elimination isn't one of them. After reading a lot, and for my environment I will probably start running Optilube Summer Formula in my gas.
I can tell you that on mine, after sitting for 3 days or so, the HPOP reservior drains empty and causes what seems like a cold start issue. No high pressure oil, no start. As soon as the reservior refills it fires off and runs fine. After the weather cools off I need to investigate, but I said the same thing last summer.
If you go over to the 7.3L forum on FTE there are a lot of good people and information available to help with anything you want to know about a 7.3L. So far I've been getting 18-19 MPG in mine, but it's a ex cab short bed, manual transmission, and likely has different gearing being a 4x4.
That door lock thing is odd. The ones you ordered definitely aren't right for the this generation of F-250. Those look more like OBS and Ranger door locks. I need to bet the tailgate lock fixed on mine. Is suppoed to have it, but someone swapped the handle for non lock version in the past. Have the lock parts, just need to pick up a handle and get the lock keyed to match. Kind of pointless right now, but I want to get a folding tonneau after I get my crunched bed corner fixed, and would like the ability to lock it up.
Need to do my window tracks. The driver side at least doesn't like to roll down all the way. While I'm doing that I want to upgrade speakers, investigate adding remote door locks, and see about adding the door panel courtesy lights like the higher trim packages and excursion had. Picked up a set of 17+ mirrors to swap in on prime day, but haven't decided if I'm going to do it or return them. If I wait much longer I won't have a choice.
Door latches are another item I need to tackle. The back passenger side halfdoor won't open, something is broken or loose in the mechanism. Need to dive in and pull the door panel so I can see if I can get it to open and find out what is wrong.
