1994 Ranger Blues
Shreveport, Louisiana
V-6 3.0
:bawling: I have been trying to locate this problem for two weeks and I have gone through two tow trucks. My check engine light has a wire loose somewhere because it affects my fuel pump. The first tow truck, I replaced the ignition coil thinking that might be the problem...How wrong I was. Well, after moving the engine fuse box around a little, the check engine light came on. So I felt that if I mounted down the box it would stay in place and work. Wrong again. Now the light won't even come on and I don't know what color the wire is or where it is located. If I could at least find that, I might find the problem....PLEASE HELP ME SOMEONE.:icon_confused:
94rangersplash
Check the EEC diode fuse looking thing under the hood in the fuse box. Take it out clean it and inspect. This will cause your fuel pump to mess up along with everything else. Just an idea somewhere to start
RedRanger91XLT
You could have a broken wire somewhere as well. But check the obvious things first.
