99 ranger speedo correction
FORD2011
ann arbor michigan
i have a 99 ranger, 4x4 xl, came with 215 originally, just put 235s on it and i know the speedo is off, but how do i change it. can i change it through the obd port?
I believe a 99 will need a Ford dealer electronic tool to change the tire size in the 4WABS module.
Since larger tires than yours WERE available stock, that reflash shouldn't be a big deal.
Shouldn't cost more than an hour of labor.
My 2000 came stock with 245/75-16.
If it's RABS, the same reflash is possible at Ford, but I believe that one is done to the PCM.
When I reduced my tire size, I simply printed out a speedo correction chart and kept it on the visor. My change was 5.2% going from 245/75-16 to 235/75-15. My speedo indicated faster than actual.
http://www.miata.net/garage/tirecalc.html
You probably just made the speedo CORRECT, as 215 tires were NEVER stock equipment on a 4x4 1993 or newer.
So some assole put smaller tires on it before you got it and you JUST reinstalled the correct size...
I really doubt that anyone stupid enough to put 215's on a '99 would have the speedo corrected.
AD
actually because it was a xl not xlt it came stock with 215. still has original door sticker, 215/75/15
Post a picture as proof. I had a 99 4x4 XL model and the door sticker specified 235/75R15.
pic of door tag
original door. original sticker. now whos the idiot. the 99 ranger xl bottom base model had 215s!
  • 99 ranger speedo correction
Easy there turbo, I didn't call you an idiot and neither did anyone else. I simply asked to see a picture because I have never seen that. I had the base model 99 4x4 xl as well, that's why I was curious.
