2.3L ('83-'97) Timing Headache
Featured Build Threads
Milton
FL - USA
Vehicle
Drive
2.3L
The timing belt on my 84 2.3L went and the inner and outer covers with it. I went through all the necessary steps to replacing the timing belt. Aligned crank pulley to TDC for cylinder 1, aligned the casting mark on the camshaft sprocket to the casting mark on the AUX sprocket and checked alignment with the dipstick. Routed belt crank, AUX, cam, then tensioner. Everything aligned the rotor is pointing to tower one. Turned it over a few times by hand to confirm alignment. Trying to start it it’s super weak and only stays on with the throttle being messed with. Confirmed spark is present and fuel is getting delivered. I am pretty stumped and could use some knowledgable insight on what to do. I put the link to the video I used for all the alignment. Newer coil pack rangers seem to have better markings.
My best guess is someone had adjusted the distributor to where the aux shaft where it shouldn't have been... if you can find the SPOUT connector and adjust the timing to where it should be that should help.
It doesn’t look like I have the ignition system with that connector. Would pulling and plugging the vacuum line to the distributor result the same? One of the steps I did omit from my repair was pulling the distributor and setting it. I assumed it pointing to #1 on TDC meant it was fine. Would it make sense to pull it out and reseat it?
I'd missed the '84 thing, don't think that would be TFI ignition so might not have the spout connector... especially if you have had the distributor out I would check the timing, there should be a sticker under the hood saying what it should be, I've never had a 2.3L with a distributor so I don't know what it should be... might take two people if you have to feather the throttle to keep it running while checking it although adjusting it one way will likely help it run better at idle until you get the timing light on and get it dialed in.
Here is a link to be starting and keeping it alive with the throttle.. any insight would be super appreciated
Thought I’d bump this to see if anyone else had any other thoughts. May just need to start throwing stuff at it and see what helps
Checking the timing with a timing light would be at the top of my list, if the only thing you did was a timing belt but had the distributor out at the same time it needs to be checked and not just that it is pointing to #1, the advance needs to be correct, there's a big difference between a couple degrees before or after top dead center...
Even tuning by ear would be MUCH better than just sight and go... With the amount of loaner tools parts stores have, surely a timing light is still on that list.
Is it possible a rocker got dislodged when the belt broke? I think it's the older 2.3l that can throw a rocker sometimes. They can just be popped back into place.
Well I hate to admit it but the issue was staring me right in the face. The plugs were covered in fuel. Obviously I got a little pedal happy when trying to get it started and flooded it. Took the old plugs out, cranked it over to blow the rest of the fuel out of the cylinders, and then let it sit for an hour or two. New spark plugs and it ran great.. For three minutes. I think the oil is fouled and/or the carb is letting too much fuel through. Had to prop the choke open so that’s a non-issue for now. I appreciate everyone input and look forward to posting more on here
Your timing may still be retarded, not giving the cylinder enough time to burn the charge. I'd still check with a timing light to see where you're at
Featured Ranger Based Vehicle
