- Apr 4, 2008
- Age
- 47
- Brasil
go to www.shadetreeconversions.com might get some interesting ideas. i to have tried to find a easy way to go the diesel rout most motors are to big the rest are to small. my thioughts maybe a 4cyl nesson diesel but then there underpowered
Here in Brasil, Ford produced a serie of F-4000 (a very small truck) in 80 years (https://www.ford.com.br/fordcaminhoes/#F4000) which uses Ford 4.268 (268 pol) tractor diesel engine. The only difference was the diesel pump inline Bosch (insted of LUCAS-CAV - in tractor)
For Rangers, the best choise is the HS2800 (135hp) engines, a developed version of HS2500 from Land Rover Defender.
In Brasil, brazilians Turbo diesel Rangers uses the following combinations:
HS2500 (called Maxion-Rover, now International - engine from Land Rover Defender - discontiued)
HS2500 - 115hps
Mazda M5R1 Gearbox
Dana 35 front axle and Ford 8.8 rear - 4,56:1 ratio (too slow combination)
BW 1354 TCase
Note? It has a very slow performace, but good marks of comsumption
HS2800 - An evolution of HS2500 made by International Engines (who own Maxion/Perkins in Brasil)called Powerstroke
HS2800 - 132cv (wg) or 135cv (VNT)
Eaton FSO2405F gearbox
Dana 35 front axle and Dana 44/3 rear - 4,10:1 (2001/2002) and 3,73:1 ratios
BW 1354 T Case
International NGD 3.0E common rail
NGD/PS 3.0 - 163cv (can be updated to 227cv by EPROM reprograming) and 380Nm
EATON FSO 2405A gearbox
Dana 35 front and Dana 44/3 rear axle. 3.54?1 ratio
BW 1354
_________________________________________________________________________________________________________
That is the Brazilian combination Ranger diesel
Do not make confusion with HS2800 engine and MWM Sprint 2.8L. Both has the same size (2,8L) but they came from too distinct conceptions
