How did your ranger try to kill you today?
Featured Build Threads
Looks like the lock nuts are both still there just loosened up a little bit and one of the bearings had enough... those dang bearings are so close together in the spindles...
Mine just tried to kill me by working really good and I was driving faster, that is until I heard the clinking noises in the rear diff on decel, I'm hoping it's not ring/pinion but probably is, at least 5.13's are still available for that...
I had a real bad fuel line leak in the engine area just below the Power Steering pump. Fuel was spraying all over the engine. It could have been lethal if this happened while on the road or highway. I'm glad I caught the leak in my driveway putting in a new starter.
The PITA got new shoes...
15x8 Jeep "Gamblers" wearing some generic 31x10.50 MT's
2" spacers from Titan Wheel Products all the way around to make up for the totally different backspacing.
  • How did your ranger try to kill you today?
Oops.
That was supposed to go in the "What did you do to your Ranger today?" thread.
But I guess it fits here too 🤷‍♂️
Oops.
Would you like it moved?
Took the bed off, by myself, had never been off since the factory installed it.
A 6’ bed is actually light enough for 1 old guy (chronologically 53 for 2 more weeks, physiologically in my 70s per several specialists)…
I’m covered in ant bites.
My bed got me today going back on with 2 people. Granted it's probably a little taller than yours...
If I hadn't had my cut resistant gloves on, likely I'd be missing the end my left pinky. It's cut on both sides thru the glove. Right at the joint.
I’ll use the engine hoist to reinstall it.
Well, the 2011 left me stranded in Ohio township. Started right up, no problem at home this morning. Not so much after church.
It's getting fuel, so I'm going to have to methodically parts cannon it until it gets fixed and stays fixed. The heat issue complicates things. Starts up fine when cold, but if it doesn't sit long enough, it just stumbles. It could be the coil pack, the timing sensor, and/or the IACV from what I'm reading.
Once I get it home, I'll check spark. That will eliminate the coil pack. But that ain't happening today.
Careful with the poison if you go that route.... Other critters who don't mind eating something that's already dead end up dead from the residual poison left in the rodent. Neighborhood pets.. fancy pants birds like owls & eagles..
I've been plagued with mice too. My mechanic told me to buy Mouse x. Put two packets in the engine compartment and 1 or 2 in the in t prior. It works.
Hit a chuck hole in a gravel road, it tried to do the hoochie coo and go in the ditch. Not fun.
The thing really needs more lead in its @$$ right now.
Add a couple railroad track tie plates or rail connectors to the rear of the chassis. I recommend the rail connectors, run as rear impact bars. 3/4-1” thick cast iron, with “speed holes”, U-bolt it to the frame as close to the rear bumper as possible.
Just curious to see how your ranger tried to kill you-- physically, financially, however.
Let me begin...
it looked at me.......then lured me inside it.
Event Coverage
Featured Ranger Based Vehicle
