Lewis & Clark Ford Bronco II
Featured Build Threads
While we're dreaming, add a 4 cylinder diesel in there. Would be plenty for something elExolorer sized.
Cummins 4BT
Ford used the Mitsubishi 2 3l turbo diesel in 1st Gen Ranger.
If you were making a Camel Trophy Bronco II from the Ford parts bin, you could use the 2.3T diesel, manual transmission, a 1.5-inch High Rider suspenpension lift from the upcoming 1987 Ranger STX, and a 31-inch tire.
I'd bump up the boost and fuel on the 2.3T to give it a V6 torque rating.
Cummins 4BT
It is already pretty close to the 2.8 rating... which is almost half of a LR :icon_rofl:
Ford still owned their ag division then, it might be better to try to raid something out of there...
The 2.2L diesel was 59 hp @ 4000 / 90 ft-lbs @ 2500
The 2.3L diesel was 86 hp @ 4200 / 134 ft-lbs @ 2000rpm
The 2.8L was 115 hp @ 4600rpm / 150 ft-lbs @ 2600rpm
The 2.9L was 140 hp @ 4600rpm / 170 ft-lbs @ 4800rpm
The 3.0L was 145 hp @ 4800rpm / 165 ft-lbs @ 3600rpm
The 4.0L was 160 hp @ 4200rpm / 220 ft-lbs @ 2400rpm
The 1985-1986 Camel Trophy used the Land Rover 90 2-door which would have been the closest in size to the Bronco II.
The Land Rover diesel made 69 hp and 117 lb-ft torque. So the 1985 2.3L diesel (86 hp / 134 ft-lbs) was more powerful.
I was looking at 1990. I also mis-remembered how much torque the 2.8 had.
Defender was 109hp @3900 and 188lb-ft at 1800rpm
Range Rover and Disco made a little more, 113hp @ 4250rpm and 195 lb-ft @ 1800rpm
It looks like a later version (300Tdi) might have actually found its way into the South American Ranger after Ford bought out Rover.
Love the exo cage on this one.
Event Coverage
Featured Ranger Based Vehicle
