Power Steering Assist Failure
Featured Build Threads
There is module programming. Time to do some research on how to do it with forscan.
There isn't much out there but what is out there is that if the firmware in the rack is the same as the old rack, reloading As Built will work, if you do get a code. If the firmware is different, the only option is to go to a garage with the Ford software and have them reprogram it.
There was nothing mentioned about driveability issues on the Forscan forums or Ranger 5G. So, I guess I'll cross that bridge when I get there. I'm going to need to get the alignment checked anyway. If I have to go to a Ford garage to get the rack programmed, I might as well have them check the alignment while I'm there.
Im getting a used rack so hopefully the programing will be the same. So hopefully i can just download my as built program and be good. I couldn't access the module reset without a license. I was planning on an alignment afterwards anyways so hopefully I can find a shop that can do both when I take it. My closest Ford dealer is almost an hour away that would do the service. We have one about 30 mins north in KY but I've heard horror stories from there.
It depends on how you use the KY.
Well the new rack is supposed to be here Monday. So today is in the 70s° outside and Monday's high is supposed to be 40°. This inspired me to get to work on removing the rack and getting ready for the new one Monday. I first locked the steering wheel in place straightwith the seat belt.
Then I took the bolt out of the steering shaft closest to the rack. Then the tie rods loose and removed the bolts.
Now I cant get it out past the front diff. So I soaked it down with some penitrating oil and will try again later. I will have more updates as it goes along.
Oh I forgot to mention you have 2 electrical clips you have to undo. A CanBus one and a power cable. Both have little red locks on them. Be careful not to pull the little locks all the way out. They dont go back in. Trust me haha
40's and tons would fix all of your problems...
Yeah but see the way my bank account is set up.... Well if someone in here would start me a Go Fund Me haha. I'm stripping all day as it is barely scrapping by haha
It is out. It would probably slide right out the passenger side on a 2wd. On a 4wd. I had to remove the inner tie rods. Not that hard at all. You could leave the outers still attached. There isn't any adjustments on the inners. I ended up disassembling the whole thingto see how it works. Looks like it uses a belt with an electric motor to drive a worm gear. The actual steering shaft will run it side to side real easy with no load. When I broke the EPS off the rack I did have some brown water roll out. Not much but still concerning. Maybe my whole issue. Its out either way. Now to get the new one in. Updates to come.
Better hurry. It's supposed storm anytime now. Then be snowing by midnight...
Yeah I know. Unfortunately the new rack is due to be delivered tomorrow. I took advantage of the warm.weather this weekend to get take it apart. The new rack has tie rods attached. I will remove them on the bench before I install it. Then reinstall them after I get the rack mounted back in.
I recently met a guy who can snake a metal tomato cage up 3 ft of narrow artery into precise position, if you think that would be helpful.
He ain't cheap
He ain't cheap
Some of those guys don't even have to be there to do it either!
They just need a robot on site and they can work remotely.
Well I layed in the snow and 33° weather and got it put back in. Just for a note. If your truck was built before 6/08/2020 it has smaller ball joints on the tie rod ends. Mine was built 6/20/2020 and it has the bigger shafts on the tie rod ends. I ended up having to use my old tie rid ends. Probably need to swap out for new heavy duty ones soon. After removing the inner tie rods you can snake it right in. The trick is to insert the steering knuckle side above the cross member on the passenger side then swing it around the front of the motor and drop it in place. After all the struggles to get it out. Removing the inner tie rods was the trick.
Event Coverage
Featured Ranger Based Vehicle
