Power Steering Assist Failure
There is module programming. Time to do some research on how to do it with forscan.
There isn't much out there but what is out there is that if the firmware in the rack is the same as the old rack, reloading As Built will work, if you do get a code. If the firmware is different, the only option is to go to a garage with the Ford software and have them reprogram it.
There was nothing mentioned about driveability issues on the Forscan forums or Ranger 5G. So, I guess I'll cross that bridge when I get there. I'm going to need to get the alignment checked anyway. If I have to go to a Ford garage to get the rack programmed, I might as well have them check the alignment while I'm there.
Im getting a used rack so hopefully the programing will be the same. So hopefully i can just download my as built program and be good. I couldn't access the module reset without a license. I was planning on an alignment afterwards anyways so hopefully I can find a shop that can do both when I take it. My closest Ford dealer is almost an hour away that would do the service. We have one about 30 mins north in KY but I've heard horror stories from there.
It depends on how you use the KY.
