Cb radio
And finally, the CB junk pile in the shed of miracles.
I’m going to swap these two for the radios that are currently in the 87 and 97. Then I’m sending those to the CB shop to get tuned up. I like them with the front mount mics for overhead, and left side mics for under the dash or the hump.
Also on the shelf:
A couple radar detectors over some small radios with a pile of microphones and some walkie-talkies on the left. The two 479s are on cigarette lighter plugs, and I have the little magnet antennas for when I’m following somebody or vice versa. Very good little radios.
Spare cobras and others. The Uniden is a great little radio, but I’m not sure if any of my mics will fit, and I don’t want to burn it up with a cross wired mic. And a third Cobra 148 GTL. And the big Realistic has some mods and switches on the side that were added, but I’m not sure exactly what they do. It’ll go to the radio shop when I send the two in the trucks. I think I’m going to use that one for the 87 town car if it checks out OK.
And the rest. The 23 channel Sears Road Talker single side band is as big as a Volkswagen, but it will look proportionally correct on the hump of the Marc V. I have to replace the Mike outlet, a task for down the road.
I think there’re a couple more, but I couldn’t find them quickly.
Wow those are cool
A couple after thoughts:
The only way you can ultimately check the performance of your system is talking to other people on the radio. Are you anywhere near an interstate or a highway where there are a lot of truckers? You can park out there, or ride along out there, and try this:
“I’m just getting started and I put in a new radio, can I get a radio check?” The truckers will feel better about talking to someone who wants to get into the hobby versus some lonely jerk who just wants to yak about who knows what.
Once you get a connection, ask them where they are, you’ll be able to get a sense about your reach distance. Ask them how you sound. Is the signal strong? Is my voice clear?
You mentioned you had a mic problem. I bet you can find somebody who’s got a good mic to just plug it into your radio and check it to see if the mic is the issue. If you have a buddy with a CB, you could do a little broadcast check dance. Park a half mile apart and see what it sounds like. Then go to a mile, etc. Please don’t do it on channel 19….
And, are you using real CB radio coax? Did the cable come with the antenna? CB radio cable is different than cable TV cable or other coax cables. A single run should be 50-ohms impedance, typically RH-58 or RG-8X cable. If you run duel antennas, which I don’t recommend. (ideally 8 feet apart, 6 foot minimum), the best set up is a cable that is coupled together at the back of the radio so there is a single cable to each antenna. Those would also be 50-ohms. If you use a double, where a single cable runs to some point and then splits into two cables for the antennas, the single line should be 75-ohms impedance, RG – 59, and the singles would still be 50-ohms. It’s very important that the two single cables are exactly the same length. Even an inch or two difference, and the two antennas will fight each other instead of broadcasting out double strength. Typically doubles would be on the same spot on opposite sides of the truck. 8 feet is close to quarter wavelength. With double antennas, they won’t interfere straightforward or straight back, but the second you’re trying to broadcast off at a little angle, one will fight the other. The greater, the angle, the more the interference, but they will still work 90° out on each side, the signal just won’t be near as strong.
The coax cable should be labeled along the side of the cable. If you splice the cable, it’s also important to splice the shielding. This is easy to do. Strip the outer skin back a couple inches. Then peel back the foil or squeeze back the braided shield. Then strip the signal wire in the center a little bit. Twist the signal wire together, or even better, solder it together. Wrap that with vinyl tape. If you do it carefully, there will be enough shield to overlap itself. If not, you can just smooth it out and then wrap it with a piece of aluminum foil to make the contact from one side to the other. It’s important that it’s wrapped all the way around. Then you can tape the outside. It’ll look prettier if you use shrink tube on the inside and on the outside, but I’m old and feeble, and I always forget to slip the shrink tube on before I put them together
You’ve got several adjustment features on that cobra 29 LTD. If you’ve got somebody you’re talking to, ask them if they’ll chat for a little bit just so you can check the adjustments on your radio. Then make small adjustments maybe just counting from one till five and ask if it sounds better or worse.
And updates on my post:
When I mounted the radios up high, I had to trim the sunvisors a little bit. It’s not that hard to do, and I could write something with a couple pictures if you’re interested. The wires are run around the inside of the windshield bolding.
On the 97, there are extra switches up above because I knew I was going to be adding additional equipment. I ran extra wires too. And I made us spreadsheet of which wires went to whatever or came from whatever, you’ll never remember a year or two down the road. I actually have a paperback GE sitting between the seats on the back of my electric brake controller with a simple little 3 foot wire whip that I use as a back up. The 29 LTD with the 6 foot antenna works pretty good at distance, and the GE works very good for people close by, but the speaker I hear is a little garbled. I put it in while I was trying to figure out the 29 LTD, but I kind of like it sitting there as an extra toy, so I’ll probably keep it.
The 87 actually has a Cabra 148 SSB (single side band). In addition to the base 40 channels, you can click it to the upper side band where you’re only using the top range of the 40 channels, or vice versa on the lower band. It has the effect of giving you twice the wattage, or three times the wattage, but you can only talk to other people who have a single side band. To be clear, it doesn’t clarify the channel, it’s like having 80 more channels, but they have better reach and reception.
The F250 has an old radio shack TRS that has four or five preset stations. Most radios have a quick flip switch between whatever channel you’re talking on and channel 9. This TRS set up has five preset stations I think. I put it in for use in New York City and a couple other big cities. In New York, there are thousands of people on highways that are only a mile or two apart. 19 is the universal channel, and I don’t remember now, but channel 10 was the Brooklyn Queen‘s Expressway, another channel was the Long Island Expressway, etc. There were always different routes you could take, so with the radio you could reach out and find out what the traffic is like on this one or that one before you exit the one you’re on, and then you can track the one you’re on without a lot of interference from broadcast from other areas. I hardly ever do that anymore, and one of the little bars on my digital read out is failing, so when I said it to 19, sometimes it says 19, and sometimes it says 13, which drives me crazy even though the radio works perfectly. I have a second cobra 148 SSB that I’m going to put in the truck. Same thing with the switches overhead.
In total, I think I have a half dozen Cobra radios, I’ve got a half dozen RadioShack radios, and I’ve got half dozen or more of other brands, all pocketbook. And then I have two or three dinosaurs.
I also have an 87 town car and an 88 town car, and a 1978 Lincoln Marc V. I’m probably going to put cobras in the “modern” Lincoln’s. I have a period correct Sears 23 channel “Road Talker” which is also an SSB that I plan on installing on the hump of the Marc V. It’s the size of an old phone book. For those Lincoln’s, I’m going to use a 4 foot stick or whip on the front lip of the trunk lid.
I’m 1 million years old, and I had a CB in my car before the big CB craze in the 70s. I’ve been fiddling with them ever since. It’s in my blood from when I grow up.
You probably figured out that I could go on about this stuff forever, but I wanted to lay out some details if you’re just getting started. When I was coming up, I had to listen to a few gray haired old curmudgeons to figure out how to do stuff, and my beef was they never went if there were enough detail. I’m probably providing too much detail, but obviously you can just Ignore the parts you don’t need, but someone else might be looking for info, the beauty of these forums.
Hope it helps. Good luck with it, keep us posted!
Yes I am using real cb coax it come with my cb I work right next to a caterpillar warehouse and the truckers are probly less then 500 feeet I did a radio check and got responses but I don’t know how well it’s working because my house is probly a mile MAYBE 2 not sure exactly but if I turn it on 19 there I don’t get squat sometimes static but not really
The All-Road is not all in the mic. It has a small box that the mic attaches to. The mic is simply the control. However, the CB you suggested is not a good option, as it is handheld and has a micro antenna. That will greatly diminish the quality of the reception when used in a vehicle.
Guess I'm not familiar with the All Road version (had to look it up). It looks different enough that it's probably a completely-new unit
The Cobra 75 NWSTX (whatever its suffix was) that pre-dated it is the one I was speaking of... The word 'garbage' doesn't describe it well enough.
The Midland 75-822 I suggested works either way... It either plugs into your car with a good antenna, OR you can use it portable. The audio quality on that Midland is very good.
I can agree portable CBs normally don't work well for range, but it is an option that's not available with the Cobra 75 radios (would be good for communicating with someone while spotting them through a tough spot on a 4WD trail, for example).
It’s my understanding, the ideal cable length between the radio and the antenna is 18 feet which is 1/2 wavelength. That’s usually longer than you need, but you’re not supposed to coil up the extra. You’re supposed to lay it back-and-forth irregularly or do a single run up and back rather than coil it. If you coil it, it can act like a transformer loop, and affect the signal.
This is true with unshielded open-wire or twin-lead (balanced) feedlines, but not with quality shielded coaxial cable.
With coax you can roll it up and it'll be fine (the signal always remains contained within the shield).
The length thing is trickier to explain, but if your antenna is grounded properly and has low SWR (<1.5:1), length should not matter significantly either.
I'm not gonna deny I may have done that a time or two myself :unsure: but really the correct advice here is to use proper PL-259 connectors & a barrel (PL-258) connector if you have to splice a cable together. You really don't want to have that piece of foil or a stray copper strand ground against the center conductor inside there and possibly causing failure of the final PA transistor in the radio (many of those old PA finals have become hard to find now if you have to replace one).
@sgtsandman
Do you have any idea what those two little switches on the side of that big realistic radio might be? And how I would test what they might do?
Quite likely it's extra frequencies (a.k.a. "freaks", or "funny channels").
Do you have a frequency counter to check it with?
×2, a picture of the area the switches are wired into might help. Those radios had the µPD858 frequency (PLL) chip which had enviable channel-capability in their day (but were outclassed by so-called "export" radios that began appearing maybe not quite a decade later).
You said you checked the SWR with your radio's meter? What was the reading on it?
I had entirely forgotten about the OG 75. Yes, I'm sure the all-road is a vastly improved unit. That Midland does look pretty solid, (XT19 territory) and I didn't realize it was able to connect to an external antenna. I'm curious how far you can turn it up before it's just a squelchfest. 🧐
Like 3 I believe
Like 3 I believe
You really need to make some tweaks to your antenna setup to get that below a 3:1 SWR, at least to 2:1 or better yet 1.5:1 (1:1 being ideal) if you're going to be transmitting. I may have missed a post but I saw something about splicing cable - any types of connections in the coax between the radio and the antenna could cause SWR issues, but usually it's the antenna itself that needs adjusting.
That high SWR _may_ indicate that your antenna isn't resonant at the frequencies you're working at, which may or may not lead to reducing your range, both transmitting and receiving. The high SWR _is_ dangerous to your final transistors though (only when you're transmitting), as 4x4junkie pointed out.
While not entirely germane to the conversation, I ran across this picture of broadcast pattern propagation and antenna placement on a vehicle. I saved it for future use but thought people would like to see it here in this thread as well. This is from Popular Electronics, Novemember 1966.
I was avoiding doing the unsolicited deep dive on antenna efficiency but we can add a couple rules of thumb to go along with those charts. Anything near an antenna (the closer, the stronger the effect and especially metal or dense materials) will de-tune the antenna, change its resonant frequency and the SWR as well as the radiation pattern, so I would tend to try to keep any antenna as high as possible and away from any objects, including the body of the vehicle. Also, antenna efficiency increases the better your ground plane is (which is a very lengthy conversation) but in a nutshell, this tends to make "center of roof" the best place on a vehicle to mount an antenna (from an efficiency point of view, not necessarily convenience!)
These are obviously not always possible and mounting antennas on a vehicle is always a compromise. It's worth bearing in mind that once you tune your antenna on the car, if you move it, the SWR may change dramatically.
Nice! Thanks!
You make a very good point. The antenna placements for both of my trucks is a compromise because of the roof racks needing to remain clear. The only antenna ideally placed at the moment is the CB antenna on the 2019 because I am able to place it right in the center of the cab roof, even with the roof top tent in place. If I need to use the roof rack on the 2019, the CB antenna needs to be removed from the roof. Eventually, I'll mount a 102" whip on the right, rear end of the bed so that the antenna can stay in place, regardless of what configuration the truck is in.
Because of the main use case of the CB radios, the right rear is ideal for talking to on coming traffic on the other side of the road since it directs the strongest portion of the transmission pattern in that general direction.
Compared to a CB antenna, mounting a little 2 meter 1/4 wave mag mount on a car is easy peasy right? Something way bigger like CB is just a question of how little you can compromise, because it's always going to be a compromise, so you just do the best you can with your particular situation and just live with it. In practice you can get away with a fair amount of compromise and still have things work pretty well.
Like 3 I believe
I’ll get back to you on that
im not sure if it was 3 I totally forgot to even look today I’ll get back on a more accurate number tomarrow do I need to be in a empty area to check it or can I just turn it on
Yea like said, you have to get that SWR lower.
How is the antenna mounted? Do you have any pics?
Mounted on my toolbox
  • Cb radio
The more out in the open the better for tuning the antenna. That spot you showed in the photo would be fine though. As long as there's nothing within a foot or 2 of the antenna you should be good.
