When you say, "3-link Panhard" ~ I ASSume you're referring to Watts linkage? LINK
No, just a normal panhard.
What's your impression of the qa1 singles so far?
Technically it’s four links in total..
Gotcha........I was thrown off by the "3-link" part. <shrug>
Hey guys! I have been following this thread for about 2-3 months now and wanted to say ill be joining the AJE gang very soon! As of about 10 min ago ( with the help of looking at all of the examples in the thread XD ) I purchased my own kit! I have a 1990 Single Cab long bed thats getting a bored/stroked 351w (408) with some twin 80mm turbos from VS racing. A T56 Magnum from RPM Transmissons and haven't fully decided yet but leaning towards a 9in Rear end so im not replacing 8.8 parts all the time. Looking forward to posting my progress and gaining some new knowledge as I go, maybe even making some new friends.
whats your plans with the truck when done?
8.8 is plenty strong. What kind of power are you shooting for? A narrowed explorer axle to make it centered would be perfect. I didn’t center mine and my 18x10.5 et 22 with 295s poke a good amount. Should have narrowed to simplify things. I’ll be adding flares eventually to get the stance I’m after. What kind of time frame are you anticipating?
And neither of us have installed anything yetAlso I thought I spent way too much money on my build but it sounds like you guys have me beat.
Motor Specs for anyone who's interested, it was just a shade over $10k
427 Liberator Dart Longblock
Dart SHP 351W Machined Block
RPM 4340 Forged Steel 4.00 Crankshaft
RPM 4340 Forged Steel H Beam Connecting Rods 6.200
With ARP 2000 Rod Bolts
Wiseco 2618 Forged Pistons (32cc, TFS) 4.125
Wiseco GFX Ring Package - turbo
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in Oil Galley Plugs
Fel Pro Rear Main Seal
ARP Main Studs
Freeze Plugs
FordStrokers Custom HYD Roller Billet Camshaft
ARP Cam Bolt
Cam Retainer Plate
SA Gear Billet Timing Chain w/Torrington Bearing
Fuel Pump Eccentric, if using a mechanical fuel pump
Trick Flow Twisted Wedge 205 11R Cylinder Heads
66cc = 9.3
Morel Hyd Roller Link Bar Lifters 5323
4130 Chromemoly .080 Wall 1 Piece Formed End
Pushrods
Trick Flow Roller Rocker Arms 1.6 7/16th
Fel Pro MLS 1134 Head Gaskets
ARP 1/2' Head Studs
Rear Sump Package
Melling Select High Volume Oil Pump 10833
ARP Oil Pump Bolts
Moroso Oil Pump Pick up - 24532
ARP Billet Oil Pumpshaft
Fel Pro 1 Piece Oil Pan Gasket
Moroso 7qt Oil Pan - 20520
> -10AN RETURN ON EACH SIDE
Mr. Gasket Oil Pan Bolts
Timing Chain Cover
Fel Pro Timing Chain Cover Gasket
