- Aug 10, 2026
- Russiaville
- State - Country
- IN - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 4.0L
- Manual
- Total Lift
- Zero
- Total Drop
- Zero
- Tire Size
- Stock
I’ve got a 93 ranger 4.0 5 speed. The pcm will not boot up. I’ve changed the capacitors already but still same issue. Acts like it’s in the voltage regulator circuit. I tried another pcm and it will run fine. That eliminates any issue with voltage supply to the pcm. Anyone familiar with board repair in these units. Seems the board schematic is proprietary to ford and I can’t find it. Also I’m still looking for another pcm for this. The one I tried had issues and I sent it back to eBay. That caps were corroded in it as well. I have a 4.0/2wd/manual. If I use an auto pcm I’m sure it would still run but with a cel. I know the 2wd/4wd don’t matter. Thanks
