- Jan 27, 2010
- Canada Eh!!
Oh and did I mention my weird clutch safety switch problem? Ok so after we finish the pump fix, I jump in to start it right, when I push the clutch pedal in the starter engaged. I was like wtf? Every time I pushed the clutch pedal the starter would turn, acting like the clutch safety switch was now my starter button. Didn't matter if the key was on or off either, mind you with the key on it would start and run, with the key off it would just turn over, no start. We messed around for a couple hours trying to figure out why when all of a sudden it stopped doing it. So now I have a gremlin in there that may pop up again one day.....fawker.
I am using an auto trans ecm and harness on this thing with the fm146 manual trans and my factory BII clutch safety switch wires I ran into the auto trans harness park/neutral wiring. Has worked flawlessly for the last 6 years and suddenly it does this but for only a couple hours then goes back to normal...........wtf? I have young kids so the clutch safety switch is a must have too, as I briefly thought about deleting it. LOL Turned out to not be the switch tho, when I crossed the terminals at the trans harness it did the same thing and tried to start the engine. No clue why or how the starter circuit can be energised by the clutch safety switch tho ?????
At least I don't have to worry about the window motor any more, the passenger side died last year and I swapped it right around the time I built the half doors.
