When I did my saginaw pump on my '95 4.0 I had to buy a high pressure hose for and older truck. The fitting that goes into the pump was different. I think they changed hose styles in '95 when they went ODB II.
Heres a comparison of the two styles. Saginaw hose is the shiny one.
Mine looks like the one on the right.....
I just picked up the metal res. pump with the horseshoe bracket from O'Rileys. A1Cardone 20-6244 for $79 and a $45 core. There were 4 of them in local stores!
Modded the bracket and installed the pulley...once I get the cooler tomorrow, I will hook it up and try it out!
My stock one died at Moab!
It looks like the one one the right and it worked on the Saginaw? I tried it at first and it leaked like there was a 1 inch hole in the hose.lol Thats when I noticed the pump fitting was a lot deeper and didnt have a tapered seat fort he tip of the line.
I'm pretty sure....
I am going to have to install a power steering cooler very soon, so when i tear it apart, i will let you know for sure.
Wow, they're not even on the O'Reilly system online. You're sure you got the 6244?
As for the PS cooler...its really a must have, especially with a front locker! Mine has been giving me trouble for quite a while. It would work great in the morning and start to fade during the day. At Moab, I boiled the fluid on the slick rock trails. Power steering fluid boils at 425 degrees!Im really going to have to keep an eye on this new pump and cooler and make sure it runs cooler than before.
So is a cooler still recommended on an unmodified truck?
