spark plug wires to distributer
camobroncII
2.9l v6
im an idiot and forgot to mark which plug wires went on the distributer cap...can anyone help and tell me where to put each plug wire on the distributer?
-jeff
master hec0
5
okotoks alberta canada
4.0L V6
there is a number 1 stamped on the distributor cap.
from the front of the vehicle the cylinders go as followed
3 6
2 5
1 4
so start with the number one it is stamped and attach it to cylinder 1
going clockwise after that is 4 2 5 3 6 and then your back to 1.
Edit found a picture of the firing order just click th elink
http://www.therangerstation.com/tech_library/images/2_9_firingorder.gif
camobroncII
2.9l v6
3 6
2 5
1 4
is this for a 88 bronco II? i tried that way and i tried 246 on the driver side and 135 on the other and that didnt work either still wont fire..
3,615
Ok the cylinder order is in fact
36
25
14
front
That link shows the firing order for ALL Ford V6 engines, regardless of year or application.
You are at the point where you need to start from scratch.
Take plug 1 out, stick your finger in the plug hole and have someone bump the key until you feel a puff of air out of the hole. Then put the plug back in, take the dis stem out and set the rotor between the two markings near the TFI module. Set the dis stem back in, adjust it so the rotor is centered between the marks again and put the cap back on. Then wire it up and time it.
camobroncII
2.9l v6
36
25
14
front
what are the normal reasons the broncos dont fire up? i dont know much about em my grandpop left me a hunting/woods truck wen he passed away and it ran for 2 days good but at the end of the day it wouldnt start and i cant figure out why
3,615
Try the TFI module. On the first 5 years or so of Ford's Fuel Injection systems they were usually the culprit in no-starts or poor running.
Check for spark. Stick a screw driver in the dis end of the coil wire and have someone crank it while you hold the driver near the hood prop-rod. If its blue-white you are good, if its yellow-orange, get a new TFI.
camobroncII
2.9l v6
alright ill have to check that out tomorrow or something..i just put all new spark plugs and wires on it cuz its pretty beat 183k miles but was running good now just wont start..
master hec0
5
4.0L V6
TFI biggest annoyance ever. i have been through about 3 in a year. just keep one in your glove box.
3,615
The small blocks and the cars didn't usually have as much trouble with them. It was really just the Ranger/B2 engines that were trouble because they lived at the back and didn't ever get any air. That's why they overheat and fry so often.
They still account for about 90% of the no start/rough running on the cars and v-8s those just had fewer overall problems after going to FI.
camobroncII
2.9l v6
is it hard to replace this? keep in mind i dont really kno to much about this stuff..motor yes distributors and electric no
master hec0
5
4.0L V6
it is fairly simple just its kinda to hard to reach. and little room. it is on the back of the dizzy 2 bolts on the back need a deep socket or a depending on what bolt is holding it in. torx
3,615
There is an easier way. Go to advanced, get your self a Ford TFI tool for $5. Slip it in there and use a wrench to undo the bolts with it. Then it will just pull down.
I've never seen a TFI bolt in a torx.
They are 7/32, and you will need a deep, thin-wall socket, which are hard to find, or a $5 common tool that can be found at any advanced auto.
kimcrwbr1
46
maplevalley WA
2.8l
It`s either or thin wall socket or torx I say turn the distributor till tdc on #1 piston note where the rotor position is and pull the distributor to change it the first time anyway be sure and use the heat sink grease on the flat surface when you put it back together you just need to make sure the rotor ends up in the same position when you put it back together. there not cheap but if you buy the cheap one you will probably be changing it again that much sooner. the last time I did it my coil was bad if you have a multimeter and some time the tech section has procedures for testing the ignition and find out for sure before replacing expensive parts GL
master hec0
5
4.0L V6
I have ran in to a torx on a tfi from an 88 and to top it off it was a security torx....
3,615
