PlumCrazy's Build
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Got my driver slider tacked up, but had to take break from it to go burn some rubber at my schools annual burnout contest.
Finally blew one...
Lockers dont like driving on a flat tire either. Driving off the track was a bit harsh.
Videos to follow hopefully.lol
Sent from my DROID RAZR using Tapatalk 2
Ford78
December 2012 OTOTM
Iowa
351w
Your rock rails look sweet!! cant wait to see the burnout vid.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I should have done the driver slider first lol. My passenger side is damaged enough that the body isnt as wide.lol
I made my driver side brackets the same as the pass, but the outter most part of the body is a cunt hair wider than the slider still. Either that or when i slammed that ditch I shifted my body over a 1/4" on all the mounts.lol
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
So where's the vid, Plum?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Its on my buddys phone. I just haven't had time to get it online yet.
Driver slider is 99% done. Had to drop the the tank for the most part to get at my rear mount. Had to rethink my parking brake cable mount too.
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
looking awesome as always man, keep it up. Cant wait to see you get that charger on there.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I cant wait. I will have a 98 short block in June to start building hopefully.
Forgot to mention the bad news. I cleaned all the sludge out of the SOHC pan and found a crack going between every main bolt hole......pissed. Looks like the engine was dropped on it.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Sliders done. Did a little testing on a tree even. I do want to add a second rail eventually.
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Man! Some people don't even bother with gussets.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Here is what I found under all the goo in the SOHC pan..
I have another one on the way.
8.8 is locked and under the B2...
Used the shock tabs a bought for the Ranger since I was too lazy to salvage the 7.5 tabs.
Anyone need a 7.5 setup for a B2? Newer brakes and 3.73s..
Robert_1967
13
White Pine, TN
302/2.9
is the bottom broke out of the pan???
Robert
posted with my rusty screw driver and a piece of twine.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Robert
There is a crack from the edge all the way to the first main bolt hole then runs down along to the next main.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I noticed my pinion seal was seeping a bit when I was under the truck doing the sliders and didnt think much of it, so I figure d I should check the fluid though. I went to zip out the fill/level plug and the square hole split and broke off flush......
I also found that my rear pinion had some play....I think the nut worked loose, so I snugged it back up and pulled the cover, ran a quick pattern to check the depth. Looks good, but back lash is a bit much.. I said screw it and left it. If my r&p grenade I have an excuse to go 4.88 or 5.13.
While the cover was off I punched a hole in it and added a fill/sight bung.
Ill get pics later.
Also got the 35 under the B2, but stripped a radius arm to beam nut out, so I will have to pull the knuckle off and weld a new one in I guess.
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
You only have 4.10s? You truck moves those 35s pretty well then.
My 2.9 must be completly shot. I have 5.13s and cant hold 45 mph lol
