302 starting
v-8power
31
Huntington, In.
that would work ok.
88mudder
waterford michigan
alright i did that, Still isnt firing up or even coming close. At least its grounded properly now.
Well im still trying to narrow it down. The distributer thats in the motor was in a 289 and it worked perfectly. I doubt that the dist is bad.
If anyone has any ideas , post em up and thanks.
88mudder
waterford michigan
alright i got a certified mechanic coming over tomorrow to lend a hand, i will keep updates coming.
projectnitemare
8
Osceola Mills, Pa
396W
Are you getting spark from the coil at all? If not get your multimeter ready. Check to see if you are getting power to the coil with the key in run, then try again with the key in the start position (unhook the starter solenoid to prevent accidents and such). If you have spark at the coil then it is in your distributor setup. You might want to call up some buddies to see if they have parts you can try. Worst case go to the junkyard, pull a duraspark system and dizzy from an late 70-early 80s V8 and hook it up. It shouldn't cost more than $30 or so. Then you can at least get the thing running and if you desire to put the points system back in you can trouble shoot that if you want to keep that system.
Matt
88mudder
waterford michigan
this is my meter. Which setting is used to check the coil voltage?
bottledgt
DCV 50. but if you really dont know anything past that, youre gonna have a hard time finding a problem
88mudder
waterford michigan
i dont know hardly anything about volt meters. The AC and DC confuse me alot. But hey at least im trying, first for everything. Im just a kid lol. I think im doing pretty good for swapping in a v8 :D
88mudder
waterford michigan
well hmm i tested 2 different coils on DCV50 and the needle didnt even move..key was on. I tried it on OHM and the needle went to 0. I think i have bad coils.
baddad457
18
Opelousas La.
Change the condensor inside the distributor. Cylindrical metal thing screwed into the breaker plate with the wire running to the points.
bottledgt
mmm, test the positive wire going TO the coil. should have 12V there
stranger
sounds like hes not using 12v in run and start positions the alt wire is not the place to get it.
bottledgt
since he doesnt know where to set a voltmeter,then im going to go with ..yes, there are some wires that are wrong. how could he posibly have wired the right ones up if he never tested them
88mudder
waterford michigan
my buddie came out today with his DMV and tested the coil and its deffinetly working fine. We ran the positive side to the battery and tried doing it that way but we still wernt getting any spark. The only thing we could come up with is a bad ignition switch under the dash. Im going to take the panel off and see whats going on under there. Ive decided to upgrade my distributer to a GM HEI setup because its more updated than the breaker point style.
88mudder
waterford michigan
NO. The wires are in the right spots, obviously if i hooked them up exactly how they were on the other motor.
