So, I’ve thought of those, the problem is that they don’t flow the gear oil correctly. You need a cover that is similar to a stock one on the inside or it doesn’t flow the oil right. Not usually the end of the world on a crawler, but a potential problem for something that sees highway speeds regularly
I had heard of that before, but wasn't aware it was a problem for the RuffStuff one. Now I wonder if anyone makes something compatible or if I'd be better off doubling up. Stock cover inside a thick plate like that. With a hole drilled in the bottom of the stock cover to allow the drain to still work.
I saw a video awhile back, think it was Yukon or someone and they did clear plastic covers in the common shapes and showed ones foaming oil and starving bearings and stuff. Was a real eye-opener for me of what goes on in there
Drove it yesterday for the first time in about a month. put a good 50 miles or so on it. Drove it to work again today
@SenorNoob
Found it, Banks has some stuff on the fluid dynamics of covers…
There’s some other videos too
Got an alignment done today in preparation for the Christmas trip. As I suspected, the Ranger was toed-out a little bit, but it had had the same alignment for 20,000+ miles and was still in spec about 6–7 months ago.
I hate how many locales have manhole covers below pavement surfaces so that hitting one is like hitting a pothole. Very common in some areas here.
After fixing the negative battery terminal and the vapor recovery line connector on the tank, it lives! I would like to thank @JJMaine for the fuel pump. The aftermarket pump will sit in storage "just in case" since it is past the 30 day return window and I used the seal that came with the pump. No one local had a seal in stock. So, I'll eventually get a replacement seal for it.
The bed is back on and most everything is connected. I just need to rewire the crossover for the logic module but until the cap is back on the truck, it isn't needed immediately. I did discover the high brake light bulb is burnt out. So, when I go to get the stuff for the cross over, I'll get a replacement bulb for it. Also, I don't know what the heck the cap installer did to the tail light connectors. Every latch was broken or busted. So, I guess I'll have to look for some pigtails at a junkyard to fix those at some point. The important thing is, it is now drive-able. I just need to get the Escape back together so it can stop blocking the driveway.
So...since you had the bed off. I am getting ready to do this as well. Pretty sure the pump is shot or on it's way out (original, how it's alive I don't know). I was going to pull the bed anyway to do some suspension. So, what should I do while it's off? Just the pump assembly? Do I do the fuel filler neck? Anything else? Might as well while it's off, I figure.
I’d only do the filler neck if it needed it. Having the bed off gives a lot of easy access to everything in the back, I’d give everything a good look over and deal with whatever issues you find, then treat the frame to prevent rust.
I'll echo what Lil_blue_ford said. Itbwill also give an idea where youbare with the condition of the bed and frame. Here, because ofnthe road salt, while it makes working on things dirtier and nasty, I sprayed everything down with Fluid Film that I normally can't get at.
If the filler neck looks like it is about ready to rust through, replacing it might be opportune since access is so much better.
Basically, just everything a good look over. Replace the pump with a Motorcraft one if you can. The adtermarket ones have a reputation of not lasting long and make sure the pump comes with a new tank seal.
If the locking ring is metal, make sure it is in decent condition. If it is pretty rusty, get a new one or rust jacking could crack the plastic of your new pump.
That's the issue. Finding OE parts for this is tough. Should I try to throw a new pump into the old assembly or just replace the whole assembly? If you were to go aftermarket, what brand(s) for pump/assembly? Heck, I can't even figure out the filler neck. My WB is 126" styleside, and nothing on rockauto or elsewhere lists as such. They all say 118" with styleside. My biggest issue is I want to order the parts before I pull the bed, since it's at least 7-10 days to get the parts if I order them.
I don't know what to recommend on a pump brand or a rebuild. Others might have some input that will help.
As far as the filler neck, there is a site or two dedicated specifically to filler necks that will probably have what you need. I believe filler neck dot com is one of them. Nothing against Rock Auto, they do generally have most common parts, but they do have some holes in what they offer.
I have mixed feelings with fuel pumps. My green Ranger got a no-name pump because that’s all I could afford when the stock pump died. Been a great pump.
I think it was an Airtex or Spectre that I put in the Choptop. Old pump hadn’t died but the tank started leaking. Pump assembly and locking ring were pretty crusty and I decided I didn’t feel like messing with it. Apparently the old pump was getting weak anyway because it ran better than ever. I hadn’t even suspected a problem.
My mom’s Explorer, I put a Delphi and I believe a Carter in. One of the two arrived DOA and the other lasted a month or two. Both bought from RA, who hassled us on warranty. That was the last time I bought a pump online. If I have a problem I want to be able to drag you across the counter so we can settle things.
Made my 98 a really short bed temporarily, it had some frame rot ahead of the frame splice, so replaced that section and the whole back half of the frame which was also stupid thin. Going to finish putting it back together tomorrow.
Got my 98 all back together yesterday except for a couple small things. Should be good for a few more years until the salt eats it in half again.
Event Coverage
TRS Merch
