well when it warms up to near 10 degrees this afternoon, I will give the prime it method a try.
I do need to do a transmission fluid change, so that is something to think about. got the filter, now I need the fluid. what does a shift kit cost?
AJ
For fluid, the red bottle Valvoline Maxlife is the correct and cheapest way to buy it, if I mind right. Mercon V is expensive and I’ve never found it in bulk other than that stuff. I’d buy a dang 5 gallon bucket if I could.
Transmissionpartsusa has the Transgo shift kit for about $62. O rings and gasket for the reverse servo plus the valve body gasket set is like $10. Apparently they don’t have the one-piece separator plate anymore.
well... today i tried the prime it method and it still took a little longer (not much) to catch and it stumbled and died as soon as I let off the key. started it back up again and it fired off right away. let it warm up in the driveway, locked the hubs in because the roads are for crap here. shoveled the drive while it warmed up. then drove it out on the town, and at a stop light the engine died. started right up again. but it felt like it had a big enough miss that it died. did it again 10 min later at another light.
At this point I am not sure if it is a fuel related issue or an electrical/ spark related issue. when it warms up I will dig deeper...
AJ
I did much more than average Ranger related today... started off doing an oil change on the '97, while there with a 15mm socket toed in one side 1/2 turn since the front tires aren't wearing great... then went to Harbor Freight to get some stuff, went to open the tailgate and it wouldn't open which hasn't happened before... got home and tore into it trying to lubricate stuff but the problem was the handle levers had both bent outward and the passenger side one wasn't hitting the linkage... should buy a new handle but gambled on bending the cast aluminum arms back into shape... worst case I still have the original tailgate... but it works GREAT for now...
AJ
Suppose it could even be a computer issue. Do you have a fuel pressure tester? That’s an easy way to help rule out a fuel issue. Check it on one prime, couple primes and running both idle and whacking the throttle. I bought one from Harbor Freight after I realized the value. Then while it’s running I put a stethoscope or long extension or something on the injectors and take a listen, they should be tapping away nice and regular.
That and pull the vacuum line off the regulator, on the '91 Explorer I had for a while the regulator blew the diaphragm and it was getting a bunch of extra fuel through the vacuum line...
Event Coverage
TRS Merch
