lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
For fluid, the red bottle Valvoline Maxlife is the correct and cheapest way to buy it, if I mind right. Mercon V is expensive and I’ve never found it in bulk other than that stuff. I’d buy a dang 5 gallon bucket if I could.well when it warms up to near 10 degrees this afternoon, I will give the prime it method a try.
I do need to do a transmission fluid change, so that is something to think about. got the filter, now I need the fluid. what does a shift kit cost?
AJ
Transmissionpartsusa has the Transgo shift kit for about $62. O rings and gasket for the reverse servo plus the valve body gasket set is like $10. Apparently they don’t have the one-piece separator plate anymore.
