A buddy came over with his son who wants a little beater pickup with a manual transmission and I conveniently have the '92 I got for parts that I didn't need... so apparently on Friday they're going to bring a trailer and get it from me. It needs some love but would be perfect for a 17 year old wanting to learn stick and haul a quad to the dunes occasionally... I'll find another parts rig... So I'll get him the parts I have on hand that it needs and possibly help find the rest... it needs a tail light, driveline, radiator, alternator and starter that I know of to get running other than air filter and stereo... seats need pulled to pull the carpet to demoss the carpet :)
Oh, and I fixed the main issues on the '90 this morning! Yesterday I welded the muffler back together and fixed the battery cable, today I redid the O2 sensor ground and made a new tail pipe hanger, this time out of 3/8" rod instead of I think 3/16" rod and gusseted it, even aired the tires up and put the mud flaps back on...
I hear the other message there. "Don;t be stupid." I normally wouldn't even buy good used tires. In most all cases it isn't worth it to me, I'd rather buy new. There are few situations where it can be worth it to me.
1) Tires that hold air on spare rims to roll something around in the yard. Have bought one set for this. Might need to buy another.
2) Mockup. Setting
3) Ferry flight. In aviation a ferry flight is a flight authorized via Special Flight Permits on an unairworth aircraft. Normally used to transport an aircraft from current location to location where it will get repaired. In the case of a car/truck, transporting the vehicle to where it can get the necessary repairs done.
in this case its a combination of 2 and 3. I don;t know if I cen get the truck lowered enough for a 29 to fit the way I want, so they are the right diameter for mocking up my suspension alterations. I can lower it enough then they have good enough tread left to drive from the house to the alignment shop, then from the alignment shop to the tire shop. If I can;t lower it enough then they'll be sacrificial for transporting to the alignment shop without destroying my good tires, then the good tires will be reinstalled afterwards. No detours planned or authorized in between, except a possible layover at home if both can't be done in the same day.
No no no, don’t misread me! You’re doing what I do/did. More power too you, I actually like your logic. & remember, after many many (many many) miles, I have almost all day 7 days to paint a trailer and screw around with this stuff!!!
@JOSH T,
And an afterthought, I joke around a lot but I never mean anything critical of anyone else, it’s all poking fun, and usually I target myself first. (I am the biggest skinflint on earth! and I regularly do bonehead stuff. It’s how we learn). I’m long winded, but, humbly, with the intent that somebody younger might learn a trick or two from my gray hair.
Having said that, if you’re getting your wisdom from me, now that might be a reason to toss in the towel!
Good luck with it, and as always, all His blessings.
Well, started off with taking some gas over to my property, put some in the Ferguson and tried starting it. After a couple tries it lit off and started racing full pelt and the throttle lever didn’t adjust anything and then it threw the battery out of the tray since I didn’t have it tied in yet. Gonna have to fix the negative battery cable now and tie the battery in. Then before starting again I’m gonna have to try to figure out what’s going on since the throttle assembly appears to move fine unless I’m missing something. Anyway, that was enough of that, other things to do today.
Gassed up the push mower and did a quick go at about half of where I can’t really get a tractor right now. That was enough of that too for me, I like push mowing marginally more than a string trimmer, which I do not own. Don’t like string trimming enough to own one, but I’m kicking around the idea of the using one with a brush blade. But that gives you an idea of how little I enjoy push mowing, lol. Probably still wouldn’t have a push mower if it wasn’t that I was given it as a non-running mower to find that the gas tank was full of water, which was the reason it wasn’t running. Dried it out, filled it with gas and it fired right up.
Well then it was back to addressing the axle seals in mom’s 02 Explorer. Had an annoying disagreement with some rust getting the upper ball joint in the rear popped out, had to work some lube in by the spray and hammer method. Ended up pretty much just pulling the entire knuckle off. Couldn’t get the axle to come out of the diff and started wondering if I was wrong and it wasn’t like the front CV axles with the retaining clip, so I went inside and first video I come across is what I’m after and he confirms it is like I thought it was, but says to use a brass drift punch and 3# sledge instead of trying to pry, then use a pry bar to pop the old seal out.
Well, my 3# sledge is up at my buddy’s but I have a 4# here that belonged to one of my grandfathers that should do the trick just fine and my brass drift punch is here, so we are in business. Got under there, got set up and gave it a couple maybe medium hard taps, just trying to get a feel for the awkward swing under there without a lift and I’m having trouble keeping the punch where it belongs after the first couple taps and then it dawns on me it’s already moving. Sweet, even less work than the guy in the video with a less-rusty Explorer had to do. Shoved the pry bar in the seal and pop, it’s out too. Sweet, now we’re making progress!
Open the new seals and wait a minute, I should have marked these but I’m reasonably sure of the two for the front axle and the other two don’t look right at all… Back in the house, double check the part numbers and they show correct, the two I thought were for the front, were for the front and the others must be the rear so I’ll give it a go, except the two for the rear are way not right. Back in the house to make a call. Parts store says those are the seals listed for the rear all the way up to at least 05. Well, they aren’t right and they actually look like they are for an 8.8” like in my F-150 (I’ll confirm that later). So he says hang on and does some searching and comes back, ok, I found the right ones, our system is wrong, you’ll have them tomorrow.
Well, I guess that’s that, delay until tomorrow. Then I start to thinking that maybe I should just go ahead and replace the lower ball joint bushing thing on the side that’s currently apart since I did the other side not long ago and right now everything is out of the way and I won’t have to fight everything to change it so I’ll get that tomorrow too. Hopefully after getting these axle seals done I won’t have to mess with the Explorer for a little bit.
Had a training class at work today (yesterday at this point) so got out early. Figuring this might happen I drove one of the trucks in and had the tires mounted on the wheels. Not ready to install them yet, but here's an idea of what they'd look like on the truck as itr sits now.
Well, ordered the weird ball joint bushing thing this morning so that should be coming this afternoon with the seals that are hopefully correct.
Looked up things and the seals that the computer lists for the Explorer rear axle (2002+) is actually the seal for the 8.8 in a 95 F-150 rear axle.
Yep, I think the Explorer axle probably has more in common with the F-150 8.8 than the Ranger axles.
Not an 02 with the independent rear suspension and CV axles, lol. My parts guy said he checked 02-05 and the system lists the wrong seal. I thought the seal number looked familiar and I was right, it’s correct for my 95 F-150. Just got curious and looked and it’s the correct seal for the 98 Explorer 8.8 as well. It’s wrong for the Ranger 8.8 though and it’s wrong for the Explorer CV rear in the 02+
Yeah, I was talking about the solid axle. I don't know squat about the independent, didn't even remember that it started in 02.
Well, I burned/melted the rubber and plastic out of the lower control arm bushing thing and knocked the center out, then fired up my WeldPac and ran some weld in the outer sleeve. Must not have had tension right on the spool because it bound up inside after unspooling too much, but I got enough weld run in before that happened that a couple whacks with the old 4# sledge and my custom punch and we were ready for the new parts.
My pastor messaged me and asked if I could help with getting some stuff to the dump so I went and helped him since I was waiting for parts. He promised me a steak dinner in return but I asked for a rain check since I wanted to get some work done. Well, come 5 pm and no parts so I pack everything up and at 5:30 here comes parts… well, that’s tomorrow’s project now.
freak hail storm customized my hood. Can see the little dimples of you zoom in on the far side. I’ve heard of hail hotspots around here for decades but never saw any.
View attachment 91708View attachment 91709freak hail storm customized my hood. Can see the little dimples of you zoom in on the far side. I’ve heard of hail hotspots around here for decades but never saw any.
Oh no! Does insurance cover that? Or is it an “act of God.” I’ve been down that road…
Tornados & hail here this afternoon (redneck riviera), but we have this this evening.
No rangers though, can’t have everything…
View attachment 91712View attachment 91713View attachment 91714
Full coverage insurance should pay to have it fixed. Had that happen with my first Ranger and mom’s 2002 Explorer, insurance paid to fix it, even replaced my aluminum cap that was hammered beyond belief.
Worked on the Explorer today, got the correct seal in the drivers side, got the new lower bushing/ball joint in the drivers side… man, that was a fight. Wire wheeled the inside then lubed things up with grease. Got it pounded in almost halfway and then it didn’t want to move. My swing was limited by the body and running boards which didn’t help. Dad helped with making an improvised puller with all thread and sockets. Broke the all thread once, ripped the threads out once, and finally got it where it needed to be. When I was cleaning the grease off the sockets I realized one that I grabbed happened to be a Snap On impact 1-1/4” in 3/4” drive… expensive socket for this, lol.
Got the other side tore apart in the rear. Have to wait on dad to fix the rust before I put it all back together. Then we get to do the front…
Event Coverage
TRS Merch
