- Aug 25, 2026
- Fort Worth
- State - Country
- TX - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3L
- Manual
Hey guys I’m new to TRS. I decided to finally join after not being able to find a similar thread with the same issue I’m running into.
2001 Ranger 2.3l Duratec Manual Transmission
200k miles on dash
For the past couple months, when I get home from work and I’m parking the truck, it will randomly just shut off.
At first I thought it was bc I had 3 engine codes:
P1537- Intake Manifold Runner Control Stuck Open (Bank 1)
P0141-02 Sensor Heater Circuit (Bank 1 Sensor 2)
P0171-System Too Lean Bank 1
Long story short the truck had been tampered with before me so I decided to replaced the intake manifold with the originally IMRC valves, I replaced the whole engine harness since the wiring had also been messed with, and I installed an OEM catalytic converter from another Ranger.
Check engine lights went away and it’s been running good for the most part, BUT it still shuts down when I get home from work while I’m parking.
At this point I’m starting to think it’s temperature related, I live in TX and it’s currently summertime.
It’s strange because for my Morning commute, when I’m parking at work, it doesn’t shut off.
But when I go home (95+degF) it shuts off while I’m parking.
I have replaced every engine sensor along with purge valve and vacuum hoses. I even put a mechanical thermostat from TRQ because the electronic one was always getting stuck closed. I bypassed the CEL by bridging a 1.5kohm resister on the connector.
I’m just lost at this point and hoping someone can help.
200k miles on dash
