- Jul 6, 2008
- Monument, CO
Here's another myth about Trucks! and Extreme 4X4, you don't need to go buy the most powerful, expensive welder to do the job. I proudly own a Handler 140 with Stargon gas hook-up.
When doing sheetmetal, exhaust, or anything under 1/8" thick material, this is the cat's meow. Anything OVER that, use the flux-cored wire, trust me, this can handle anything up to 5/16" material with proper joint preparation. I built a hitch receiver for my truck and this can pull a D-11 bulldozer if it wanted to.
The properties of flux core allow it to easily penetrate steel and give a very strong bead, just make sure you switch the polarity around when you change wires, and that you know the proper technique for welding flux core. It does take a certain finess to make it look good.
You can also stack the weld beads on top of each other when doing thicker steel projects. The more the better.
I have a 110 wire feed. It is good for small jobs with sheet metal and such. I would not trust it on alot of my jobs though. Welding axle tubes, spring mounts, trackbar mounts, etc. Sometimes you can can't grind a notch in the material and fill it up to ensure proper penetration. I mainly keep it around for convience. It is easier to pull it out and plug it in then plug in the old buzz box. If it wasn't for the sheet metal I would use my 220 buzz box for everything. You can't substitute good old fashioned heat to ensure penetration. Heck, when I welded my knuckles on my buzz box was nearly all the way up.
We used Galvanized pipe and a bunch of sheets of diamond plate. I was sick after a week of that.
