- Sep 28, 2025
- SHELTON
- State - Country
- N/A
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Manual
Well, where to start? I have a 99 Ranger with a noisy transmission. I've had it in to the mechanic, who figures it has some bad bearings. He did change the transmission fluid, but warned me beforehand that it would probably make no difference. It didn't. But there were no alarming things coming out of the transmission. Just old fluid.
The transmission functions perfectly. While if 5th gear, it makes a terribly loud noise who's pitch depends on the speed of the truck. Also louder when accelerating. 3rd gear has also started making a moderately loud noise. Same behavior. I've also been told that the clutch slave cylinder is leaking, though I've not seen the fluid go down yet.
Normally I'd say "fix it, fix it fix it; shut up and take my money!", but in this case, it would cost over $6k, and I don't have that much to spare. Oh, he also said that it should be ok to drive the truck until I can't stand the noise anymore. In the meantime, I've put some medical restrictions on the truck: no hauling or towing heavy objects, no long distance travels, no more using 5th gear, and don't go over 60mph.
I normally stick to small engines. Motorcycles, lawn mowers, that sort of thing. But that price tag though! Makes me sorely tempted to try to tackle this myself. I've done lawnmower transmissions. Automotive manual transmissions are larger with extra parts like syncros, but otherwise pretty similar, yes?
So here's what I think I know so far:
I have a manual 5 speed with electric selection between 2WD, 4-Hi, and 4-Low. I think that makes the transmission an M5OD.
It's a 99, so it's also an M5OD-R2, or M5R2? I'm a bit confused on that one.
Removal seems pretty strait-forward. Disconnect the battery and starter motor, electrical wires, hydraulic clutch line. Remove a cross-member, and a mounting bracket, remove the drive shafts, and the 4WD gear box (I forgot what that's called), remove the shifter arm in the cab, and remove the bolts from the bell housing. Let gravity do the rest.
I've collected a few things from around the internet that I think pertain to the project:
https://www.therangerstation.com/te...ford_m5od_manual_transmission_shop_manual.pdf
https://transpartswarehouse.com/catalogsearch/result/index/?cat=9641&q=standard ford m5r2&p=2
https://www.therangerstation.com/tech_library/pdf_documents/ToyoKoygoMazda.pdf
Have I got anything right so far?
I'm thinking I'll buy a shop manual for the truck. Maybe I can buy one specifically for rebuilding the transmission? I really like the ones with pictures. I'm not afraid to read articles, so if anyone has useful links to share, I'd love to see them! I probably won't be starting this for another couple of months, so plenty of time to gather info.
Edit: Thanks again everyone for your help. I'm embedding the videos I made here as they may help someone in the future, or at least provide some entertainment.
