rkbonds1
My 93 4.0 Ranger has the lifters ticking. Someone suggested I put some Marvel Mystery Oil in and see if that helps. My question is do you put it in and leave it like normal motor oil or do you put it in and let the truck run for a bit then change the oil? Never used it before but, have heard good things about it. If it did/does work it would save me a bunch of $$$ if not next year I get to pull the heads and change out the lifters. Thoughts, ideas? I have used seafoam before and you have to change the oil after running it for a little bit so, I just want to be sure I do it right.
