- Jun 19, 2013
2004
- Manual
I have searched and searched and cannot find anyone that has had this problem. here is what i have. i bought an 2004 Ford Ranger that had a bad motor(timing chain bad). when i got it the motor was half apart. i have since bought a motor off the local junk yard. after installing the motor i go to start it and nothing happens at all. i have read on the anti theft light is supposed to flash but mine the light does not come on. i have grounded the starter relay located in the engine compartment in order to get it to crank with the key. i have checked the fuel pressure and also have spark. the motor will start with the relay grounded and spraying carb cleaner in the intake tube. the bulb in the cluster is good i switched it with a know good one. I am out of ideas with this truck. any help will be great Thanks
