FORD2011
- Sep 11, 2010
- ann arbor michigan
- Automatic
i am putting a 99 4.0 sohc from an explorer into my 99 3.0 ranger. i believe the swap will be pretty simple the only problem i see is fuel pressures the sohc runs a 65-75 psi where my 3.0 runs at 30-40 how could i increase my fuel pressure can i just change the regulator? will the entire explorer pump assembly fit in my tank? need help!!!
