- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
This is basically copy past of what I just posted over on TurboFord.org, but I wanted to get input from TRS as well.
I have a 85 Ranger 2.3L Auto, with P/S and AC. At current the long term goal for my truck is to build a turbo motor, setting a target of 300-350 HP turboed. That's not a hard set number, it's a number to build towards and I'll stop when I'm happy with it. It will be a while before I even get to the turbo phase of the build and I don't plan to stay stock in the interim.
What modifications can I make to improve the power and performance of a naturally aspirated 2.3L that won't be wasted when converting to turbo charged?
A few limits I can set are that my gear ratio is set at 3.45 open (stock 7.5") or 3.73 LS (Explorer 8.8") for the time being, just depends on which axle I use. Not sure about tire size yet, but probably 245/45R17 (or similar OD) on Mustang wheels. Will be retaining the power steering and AC, but am upgrading to a 3G alternator. I'm trying to not mess with the bottom end until I go turbo, or necessity forces it. I will be retaining the A4LD, but probably a beefed up version when the time comes.
Camshaft - I'm already figuring that a roller cam conversion would be a good move. If I'm changing cams I would not stay stock. Would a camshaft bought for a naturally aspirated engine still be good once the boosty bits are added?
Cylinder Head - Porting is always good right, turbo or NA? I'm not sure that I'm ready to undertake the DIY porting job. I have little doubt that I could do it given time and a spare to practice on. I think this is something I'd be better off hiring out, or buying a head that's already been built and ready to run. If I hire it out, what other work should I consider having done at the same time? If I'm going to port, does it matter which head I start with? If so which one should I start with? This is a single plug 2.3L, would my EFI intake manifold even fit a dual plug head with the second plug holes plugged?
I'd probably be better off waiting for a used already built head to pop up for sale somewhere, but considering my options. Don't like the price of the BoPort heads, but if that's the only option, I might do it eventually.
Injectors - Is there anything to be gained from going to larger injectors while NA? I'm pretty sure the answer is no, but I figured I'd ask.
Tuning - It is EFI and EEC-IV if I'm not mistaken, and either speed density or I'm missing a MAF. My recollection tells me that the speed density systems will require tuning to support even minor modifications like a different camshaft. Am I remembering right? What options do I have for tuning? The only one I can come across that still seems to be around is Moates, but they list as being for 1986-2004 Fords. Does anyone else still make a tuner that will work with these early EEC-IV systems?
The only other option seems to be standalone EMS, either MegaSquirt or PiMP (which is MS3). I know that Moates can handle the turbo, but the other features offered by a standalone EMS sounds interesting. Especially computer controlled ignition, CNP, and sequential injection. That said, I'm not certain that the added expense of these systems are warranted before I get the turbo installed, but I hate to spend a few hundred on Moates and replace it all a few years later. Also which ever route I take, I'll need to have the ability for remote tuning. I don't have a problem installing and basic setup on an aftermarket EFI, I've done it with a Holley system, but I'm not in a position to dive into learning EFI tuning right now. I will be making an effort to learn EFI tuning after I get done with college in a few years, but until then I need to be more focused on the education.
Like I said at the start. Excluding the limitations stated, what ever changes I can make that will boost power and performance of both a NA and Turbo engines is on the table. Will be slowly buiulding up to it, but want to head in the general direction of a 300-350 HP turbo motor. Not saying that I will ever reach that power level, I'm going to stop when I'm happy with the truck, that's just a figure in my head to work towards.
