1. my transfer case output is hanging down -7 degrees so should i just weld the leaf pads on to match + 7 degrees (taking into account the angle of the leafs and the taper of the ford block) so that they are parralel? or should i try and make a new crossmember that holds the transfer case flat at 0 degrees and make my leaf pads parralel at 0 degrees as well ?
also what gear oil should i run in the diffs?
oh, and DO I NEED 1350/1330 U JOINTS FRONT AND REAR ?
what kinda pitman arm should i use, i have stock, 6 inch lift arm, and the extreme drop?
i dont know whether im gonna run high steer right yet.
is there anyway to run hydro assist without high steer?
im thinking that to make a track bar parralel with the extreme drop pitman arm, i would have to create a really long track bar mount which would probably compromise strength.
WHAT ARE YOUR GUYS THOUGHTS?
does anyone know how much more work is required?
im thinking of welding the wedges on and running the same setup that i was gonna run with the dana 44. but i still havnt decided
will i probably have to get beefier driveshafts and reinforce the frame?
can i still use the 1330/1350 u joints ?
what knuckles do i need for high steer?
You should've figured this shit out before tearing your truck apart.
Make your t-case flange and pinoin flange parallel. Whether that's 7* or 0* is your choice. I'd leave it at 7. Puts less of an operating angle on your driveshaft.
Run whatever gear oil you want. If you want to get down to the nitty gritty, look up what ford recommends for that axle. Google is your friend.
1330 and 1350 refer to joint sizes. Measure the size of the joints and yokes you've got, and get the appropriate joint.
Run whatever pitman arm you want. The general rule is the flatter the drag link the better. I've got a stock arm and high steer. If I had a drop arm, it would be too flat, and I'd run into problems building a trac bar on the same plane due to packaging issues. You may not have that problem if you run more lift. I've only got ~3.5" of compression.
wtf does hydro assist have to do with high steer? Its a hydro cylinder that attaches to your tie rod (or knuckle, or wherever works) that provides additional steering force. Whether you've got high steer or not is irrelevent.
How much more work is it to build tons over 1/2t? The real question should be how much more money. They're both axles. It takes as much work as it takes. They both have gears, carriers, axles, knuckles, bearings. It may be a KP60, but that still doesn't make much difference. It'll just cost you 3 times as much money to build the tons vs the 1/2t.
Are you increasing the torque output of your powertrain? If not then your driveshafts will be fine, as long as you can find a joint that will work with the tons.
Frame reinforcement is up to you. They're heavy axles.
The knuckles you need for high steer have to have a flat top, duh.
Most of this stuff is common sense. If you're wondering if something will fit, grab a tape measure and find out. If you wonder how much work something is, search for other builds.
What it boils down to is its
your truck, and
you need to decide if stuff will work. Every application is different.
