gasoline fumes
Featured Build Threads
I’d swear my square nose (92) has a plastic tank… 🤔
They do, he’s talking about trying to swap an 88 metal tank in since his plastic tank appears to be cracking
Hmmm............Amazon sells 6AN braided PTFE all inclusive kits that people seem to like.
This would be full length braided too.
I would probably watch a YouTube video to learn how to attach the fittings
Kind of a weird brand name
The brand is called 'Evil Energy' $100 or less for the kit.
been using them almost since they started. have had pretty good results with evil energy.
most everything you need for A/N is workable...
for inspection purposes you could go to a fuel cell...or adapt a later tank.
Swapping the wrecked 92’s tank into a 1949 Dodge truck. I understand the whole reduce-reuse-repurpose entirely too well…
Oh I understand, I’ve done my share of junkyard shopping, lol. I’ll use a part from anything as long as it does the job I need it to. Spent a lot of time wandering around junkyards with a tape measure looking for ideas and solutions. The yards that knew me knew to just let me through and let me poke around, I’ll be back when I’ve found what I’m after to either pay for it or inquire as to the cost.
I did not forget about following up with you guys. I need to schedule gas tank repair and fuel line replacement at the same time.
I will probably use rigid nylon tube from tank to engine bay and return line. Then I'll use stainless steel braided in the engine compartment. I have to get the right diameter adapters and quick connectors also. And they need to be reliable against leaks of course.
But is there anything against using a rubber type reinforced fuel hose made for higher psi fuel injection ? (only for the under body segment.....not in engine compartment exposed to heat)
I’ve used the rubber fuel injection line before all the way up. It works. Ethanol seems to do bad things to rubber if it’s not the actual fuel injection line.
Wow......rubber fuel hose right up to the fuel rail ?
Well, I think I will go with the beefed up rubber hose at least for the underbody segment.
As long as you keep it away from the exhaust by a few inches (and ideally some insulation), yeah. That’s how the old carburetor systems were done
Ok. I didn't know that.
I found this synthetic layered rubber fuel injection hose. It's 300 psi working pressure and works with ethanol too
My fuel rail (fuel injected) connections take female threaded fitting nuts . I'm assuming I should use a compression ring fitting there.......and push on barb or quick connect with clamp not advisable?
I received a detailed email reply from Evil Energy.
He said the inner fuel line material is FKM, and it will not leach any micro-particles into the fuel injectors or engine......because it is
not generic synthetic rubber hose
At $2/foot that isn't bad, looks like the Lawrence Marine red lined stuff with the teflon liner on the inside, aside from being good with ethanol and such the real reason it's there is for evaporative emissions... I wouldn't worry about using that as long as you are careful around the exhaust, we've been using similar hose at work for many years so it's on thousands of boats...
Good to know Scott. I think the teflon liner is the best you can get for fuel and ethanol.
I just need to order the two adapter fittings for the fuel rail and pressure regulator connections.
I have all the other parts I need.
This morning I disconnected the fuel lines in the engine bay to see what diameter adapters I need.
For the fuel pressure regulator threads, I got 1/2 Inch diameter female.
For the fuel rail line fitting threads, I get 9/16 inch diameter male.
I can't find 1/2 inch diameter fuel line threads.
Is is likely both fittings are 9/16 inch threads (6AN)......and my thread measurement was off?
I included pic of disconnected fuel lines.
The top fuel line is for pressure regulator.
The lower fuel line is for the fuel rail.
Are you sure it's not metric? I thought they all went metric decades ago...
1/2"~13mm
9/16"~14mm
I just looked again on Amazon. I see M14 . But I don't see any 1/2 inch-13mm thread adapter fitting for fuel lines
Event Coverage
Featured Ranger Based Vehicle
