gasoline fumes
I’d swear my square nose (92) has a plastic tank… 🤔
They do, he’s talking about trying to swap an 88 metal tank in since his plastic tank appears to be cracking
Hmmm............Amazon sells 6AN braided PTFE all inclusive kits that people seem to like.
This would be full length braided too.
I would probably watch a YouTube video to learn how to attach the fittings
Kind of a weird brand name
The brand is called 'Evil Energy' $100 or less for the kit.
been using them almost since they started. have had pretty good results with evil energy.
most everything you need for A/N is workable...
for inspection purposes you could go to a fuel cell...or adapt a later tank.
Swapping the wrecked 92’s tank into a 1949 Dodge truck. I understand the whole reduce-reuse-repurpose entirely too well…
Oh I understand, I’ve done my share of junkyard shopping, lol. I’ll use a part from anything as long as it does the job I need it to. Spent a lot of time wandering around junkyards with a tape measure looking for ideas and solutions. The yards that knew me knew to just let me through and let me poke around, I’ll be back when I’ve found what I’m after to either pay for it or inquire as to the cost.
I did not forget about following up with you guys. I need to schedule gas tank repair and fuel line replacement at the same time.
I will probably use rigid nylon tube from tank to engine bay and return line. Then I'll use stainless steel braided in the engine compartment. I have to get the right diameter adapters and quick connectors also. And they need to be reliable against leaks of course.
But is there anything against using a rubber type reinforced fuel hose made for higher psi fuel injection ? (only for the under body segment.....not in engine compartment exposed to heat)
I’ve used the rubber fuel injection line before all the way up. It works. Ethanol seems to do bad things to rubber if it’s not the actual fuel injection line.
Wow......rubber fuel hose right up to the fuel rail ?
Well, I think I will go with the beefed up rubber hose at least for the underbody segment.
As long as you keep it away from the exhaust by a few inches (and ideally some insulation), yeah. That’s how the old carburetor systems were done
Ok. I didn't know that.
I found this synthetic layered rubber fuel injection hose. It's 300 psi working pressure and works with ethanol too
My fuel rail (fuel injected) connections take female threaded fitting nuts . I'm assuming I should use a compression ring fitting there.......and push on barb or quick connect with clamp not advisable?
Upcoming TRS Events
Featured Ranger Based Vehicle
