hardrocker31
I changed my 3.0 to a 4.0 and now I need an ECU. Does the product code really matter? Should it be 1L5A 12A650BFB
Do you think it will work? Or do you think i need the trans harness from the 4.0?Good luck with it dude
So since i kept the 3.0 trans and wired it to the 4.0 engine harness and it worked but not correctly. Do you think i have to get the 4.0 trans? I didnt get it cause mine was 4x4 and the 4.0 wasnt. Would've had to open up and change output shaft and suchWelcome to TRS
Assume 2001 3.0l Ranger
What year is the 4.0l engine and transmission from?
1990-2000 Ranger used 4.0l OHV engine
2001-2011 Ranger used 4.0l SOHC engine
So different wiring harnesses and Computers
1L5A 12A650 BFB
1 = 2001
L5 = Ranger/Mazda B-series
A = department that made it
12A650 = Ford engine computer, same number from 1986 thru 2023, in ANY Ford model, just mean engine computer(PCM)
The BFB at the end is for what engine and transmission it will work with, but Ford NEVER publish a cross reference for these
1L5A-BFB is a valid part number for a 2001 4.0l Automatic Ford Ranger
You can see what works at https://www.car-part.com/
Use YEAR of engine
Computer Box Engine
Skip areas
YOUR Zipcode
SEARCH
A new window will open and list all the Valid Computer numbers by engine model and transmission(AT or MT, manual)
Select what you want then Search
It will show local wrecking yards with that part
Since 12A650 was used on ALL Ford computers it's usually left out on reference numbers
i.e. Electronic Control Module, (RH rear firewall), 6-245 (4.0L), AT, ID 1L5A-BFB <<< 12A650 left out
All the others listed that match year, 4.0l, with AT would also work
You also need the engine wiring harness with it, 3.0l harness won't work
What I read says 4.0 engine "harness"How did you bolt a 4.0 engine up to a 3.0 transmission?
i grabed a 95 computer, so it was stuck in limp mode im guessing cause the computer couldn't control the newer transmission
