Do mirrors from a 10th gen f150 fit a 4th gen ranger?
Featured Build Threads
How do you people take a thread about swapping a side mirror and turn it into such a heated conversation? One of you was dropping language like this struck a personal nerve.
Once when I was moving I pulled a uhaul trailer down the interstate with my '83 Ranger and is started swaying and scared the crap out of me. That's the scenario where people jacknife and or roll over. I was young, dumb, and wasn't looking at tow limits and ratings. I also once moved my uncle's boat for him with my '83 Ranger, but I didn't have to get on the highway.
The concern when you start discussing something sketchy is that some kid out there might read the forum and get the idea that his fawkin Ford Ranger can tow more than it's actually capable of and not know the towing capacity of his Ranger and the weight of his load.
Know Before You Tow.
Now then, play nice, no lectures, and stick to talking about mirrors.
When I saw that I got tagged in this, I had this silly idea that it was going to be for some new tech that needed to be added to the library.
Hmmm, ok, then let’s try this.
If you have the proper mirrors while you’re towing something you should never tow in a million years, and you set them up right, you can see what a jerk you’re being.
No, wait, scratch that
If anyone has actually added tow mirrors to their Ranger would they happen to have a photo? I’m also not sure if it wouldn’t make it look stupid like putting wings on a smart car.
I'm thinking about them if I rent a trailer again. We rented a 21-or-so footer for the TRS event in October (see the Events Forum, TRS Fall Colors Campout). The Ranger had no trouble with the 4500# trailer using a Curt Echo brake controller but when going straight ahead on the highway I couldn't see behind me. Nothing to do with weight, just that the trailer was wider than my truck.
superj said:
my 3.0 will strip the splines on the axles. its that powerful. :)
If I mash the gas on my 2.3 Ecobeast it breaks the tires loose at 35 mph when the boost spools up. :)
Rated to tow 7500# and I thought you've got to be kidding me, until the first time I rotated the tires and saw how big the brake rotors are.
Darn! They don't fit. It's not far off though. The truck in the photos was an F150, and the mirror was off a 97 ranger. If I would have thought about it I would have tried it on the ranger to see what actually needed to move, but I didn't have much time. As you can see, the studs on the ranger mirror are too close together. at the bottom. The plastic trim is also a little bit too small. It could probably be made to work, but either the mirror or the truck is going to get drilled.
  • Do mirrors from a 10th gen f150 fit a 4th gen ranger?
View attachment 148663View attachment 148664View attachment 148666View attachment 148667
I went through that when I wanted to put wider mirrors on the Road Ranger because of the long trailer. They look very similar, but they don’t bolt up. I ended up using the Aluminum triangle brackets, and I converted my Ranger mirror holders to mounts for the CB tennis.
The bottoms are from an early 90s F series truck. The mirror and the arm on top are from a 70s vintage Chevy or GMC. It’s 10 times more solid than what you get today. That mirror arm is solid stainless steel that was drilled and tapped.
And I can flip the mirrors in and flip them over when I’m not pulling the long trailer.
🤦‍♂️I wish I would have thought about that antenna trick. I added the newer style 2011 Ford Ranger Mirrors.
Just an FYI follow up, the antennas didn’t just work in the hole when the mirrors were removed. I had to do a lot of work fabricating a plate to go on the bottom for a ground plane, and fiddle around a lot to finally get the things to stand up straight. But I love them now.
Event Coverage
Featured Ranger Based Vehicle
