Cb radio
Featured Build Threads
Thank you guys
Is there a specific way to wire in a cb anybody got a forum open for that?
One wire goes to ground, one ground goes to power (either key or battery power) Then run a cable for the antenna.
i would run the antenna cable through one of the cab vents in the back of the wall under the carpet. then use a body mount that holds the antenna up a bit so the signal can skip off the roof of the truck or you are going to lose some strength from half the antenna being blocked.
or run it to the front and use a hood hinge mount
I will have to find these cab vents your talking about but thank you
Is battery good so then I can turn it on and off or should I do key what is like best I guess?
Cb radio
side mount like this
Cb radio
hood mount
Cb radio
bed mount
two of those pics are from this site so somewhere there should be more info
Really depends.
I started out running it off key power. On trail rides it is nice to have the radio working when the key is off so I switched it to battery power. It also picks up less electrical noise going straight to the battery.
Really depends.
Okay thank you
What length of whips should I get l? Should I run 2?
Whatever you want to do, the internet will die before CB users agree on which setup is the best.
I believe I have read several places that multiple antennas need some separation. So, placing one on each side of the cab, like you see big truckers do, doesn't work well. Our trucks are too narrow. If you want dual antennas, opposite corners of the truck might be better.
In my opinion, just stick with one good quality antenna with optimal placement. Longer ones are often better.
Here is a thread that discusses some of this. I kind of picked the middle of the duscussion. So, scroll backward and forward a bit to get all the info.
Post in thread 'What did you do to your Ranger today? (Part Deux!)' https://www.therangerstation.com/fo...ur-ranger-today-part-deux.186616/post-2046027
Event Coverage
Featured Ranger Based Vehicle
