Bummed, motor stuck again (rant)
Denisefwd93
South East PA
this is more a rant than asking for advice,
I'm selling my 93 long bed 4.0 four-wheel drive, thisthis winter I couldn't get in the four-wheel drive after the snow is gone, then! I could get it into 4 wheel drive, now I'm trying to sell the truck and four-wheel drive won't go in again! I'm so tired of crawling under trucks! I'm ready to hit it with a hammer LOL
On the 94 supercab I haven't even attempted to play with the four-wheel drive Electronics an electric motor yet.
But, while vacuuming out the cab, I put down one of the jump seats and found the module is unplugged so I plugged it back in, that's as far as I went any advice there before I even start? Lol
Still thinking about my other discussion on using a flexible shaft to complement the shiftster.
I may just take apart a shift motor and check if that bushing on the gear is gone.. looks easy enough. (easy?) after it's out!
Yes, the electric shift motor is the usual problem if you don't have 4WD, unless you have a 1998 to 2000 Ranger then its the PVH hubs, lol.
Primary reason for failure is disuse, its an electrical device with moving parts that is exposed to the elements and never used, until it is and we are surprised it doesn't work :)
The rotor and brushes get corroded and stuck, so no electrical contact when you try to use it.
I shift my 1994 into 4WD high then Low then back to 2WD once a month sitting in the driveway, that was AFTER I had to work on it twice when it failed to shift when I needed 4WD but hadn't used it in 8 months, so learned my lessen, "use it or lose it"
Good rebuild info here: http://www.explorerforum.com/forums/index.php?threads/how-to-rebuild-4x4-shift-motor.123542/
1994 and older shift module info here: http://www.therangerstation.com/tech_library/4wd_control_module.html
before the shifster and i guess to this day some people incorporate versions of these. yeah ya have to ha a handle in the way and a hole in the floor....but it works.
I have 98 T-case in storage, I took the motor off at today I was amazed at how easy the shift shaft turns!
Bobby That right angle Drive could be very handy and some of thecreative engineering that I do in the wee hours of the morning when I can't sleep!
well...i hope the pics work now...
Pictures worked fine Bobby! Thank you the check-out procedures for that module are very involved OMG and I thought computerized air conditioning systems are hard to diagnose? Omg
Shift modules primary concern, new or old versions, is POSITION.
Shift motor has a contact wheel inside, by contacts being open or closed the shift module "knows" the position of the transfer case shift rod.
When you select 4high, the module sends 12v/ground to the shift motor and it moves contact wheel and shift rod until the contacts are in the correct "position", open/closed order for 4high.
At that time shift module will turn on the 4high light on the dash, so light coming on is dependent on the contact wheel, not on the dash board switch.
If 4WD lights flash that means the shift motor contacts were not changing, this could be blown fuse or stuck motor.
When mine stopped working I left it in 4wd with the front hubs unlocked.
