Barney and L’il Bit
Probably getting purple shock boots. Bright red springs. Kindergarten color wheel flashbacks. 😵‍💫 Red plus blue makes purple. 😊
  • Barney and L’il Bit
Shooting for chassis finished, truck drivable, by Trunk or Treat. Not finished, as if they ever are, but a reliable, safe project that can fill in when needed. Fully expect Shelby to steal it for her wildlife rehab, advertising.
I will remove the bushings before I actually strip/paint the spring pack. I might flip both the side -and- the direction when reinstalling. On my old 56 210 Delray street legal drag car, the clamps were up front. Supposed to help “load” the pack to combat wheelhop.
But thinking of just swapping sides, regular install, with the 1000# add-a-leaf slipped under the factory clamp…
Not going back on until the back of the frame is finish painted, inside and out. Brushed paint, tends to drip…
Decided to get the outside edge and underside painted anyway. 1 light coat, 1 heavy coat, 10 minute tack up in between. Will get 2 more coats later today. Once dry, flip it and do the inside edge and the top.
Not worried, at all, about drips, runs, sags or brush strokes. This is functional, form is secondary. But, having “uniquely” done vehicles is something I do anyway. Even though I’m in law enforcement my own self, standing out lets the locals know that I’m not doing anything they need to worry about. If they recognize me that quickly, I don’t dare… 😉
Trying my hand at a custom upper panel covering.
Yes, drilled off the smashed gray from the back of the main door card.
If you have never dismantled a Ranger door, not much to them…
Cheap, heat/UV sensitive ABS plastic. Vinyl board instead of plastic sheeting for wind noise and moisture intrusion reduction.
I may still try to retrofit the 1992 doorcards. These burgundy ones are, for lack of a better term… Snafubar…
