Barney and L’il Bit
Featured Build Threads
Heather’s94
5+ Year Member
Brighton TN
Barney is the burgundy 94. L’il Bit is the red 97. Both are rcsb 2.3/5spd rwd beaters. 246k+ on Barney. 284k+ on L’il Bit.
Barney is mine. L’il Bit belongs to my “work niece, farm daughter” Shelby, who dailies an 07 version of L’il Bit, but with a haunted 4spd automatic.
Barney is going “Faux Street”, good tires, decent(ish) alloys, every suspension enhancement I can make to a stock ride height 2wd.
L’il Bit is just getting cleaned up and made a runner again. It tried to eat a deer. Both died…
  • Barney and L’il Bit
Yes, Barney was the paint stand for a set of aircooled VW ARE 8 spokes. 1972 Super Beetle project for my wife. She’ll end up with Barney, she’s 5’5”, Shelby is 5’2”, they fit in standard cab minis better than I do.
My “minitruck” is a 108” wheelbase 1949 Dodge that is getting a 92 Ranger 5spd and newer Ranger 8.8” rear axle.
Both slated for this front end treatment.
The dark purple is being used across our fleet of pickups: 1949 Dodge, 1969 Dodge, 1985 C10 swb lowrider, 94 Ranger, 99 K3500 dually.
The deep red is what I’m leaning towards for L’il Bit. I really do treat her owner as my daughter…
G2 Redfire? Nice
The 2007 and its occupants… Yes, those are in fact antler tines on her hat. Both red trucks are her’s. Yes, that’s a Merle Pittie, no, he does not bite.
This is the haunted/cursed truck. 2.3 Duratec, slushomatic that failed hard enough to replace instead of rebuild, efi/ignition gremlins.
I might rethink the fiberglass monoleaf conversion on Barney. Door label info:
F/R tires: P225/70r14SL on 14x6.0J alloys.
F coils: 2150 lbs, 975 kg
R leaves: 2384 lbs, 1081 kg
GVWR: 4220 lbs, 1914 kg
Built 08/94 USA
Paint code 23
Body code ER
Axle code 84 (3.45)
Not too shabby for a pocket sized truck.
Only actual front end damage? Grille center crack, some peeling VMD “chrome”… 2 spots of airdam bolt pull through. And the hood paint looks like ancient lacquer.
1977 Dodge L’il Red Express take off, Lt235/75r15 load range C all terrain. Fits like it was made for the Ranger. I should have push through caps and correct 70s chrome dome lugnuts. “Really” want these wheels on my 1940s truck though, but I like them here too. Damned shame they need to be rechromed, could have straight swapped 2 years ago for same size cast aluminum version.
And going through the garage this afternoon, found enough 6’ oak tongue and groove to build a “ show deck” for whichever project turns out nicer. Probably the “haunted/cursed” ‘07, since it has a fancy leather interior and better sound system.
I like the jelly-bean rims.
Just about free from the sw TN jungle. The tree in front of him is a roughly 200 year old black walnut, with limbs big enough to harvest billets for Turnbull
Barney and L’il Bit
Restorations (pre-1900 Winchesters mainly).
Spent hours trying to figure out how to boost the headlight output. ALL exterior lights are new housings/bulbs, but, I recall that they weren’t great.
Only to find that “that” most hated of suppliers, LMC, has a hd harness for less than I can buy the components. Just like the 60s/70s Ford harnesses going in my 1949/69 Dodges. Or the harness for Ralph, the 85 C10 swb lowrider project. I do hate dealing with them about as much as I do Rockauto, Vatozone, or Advanced, but…
Are you going to stick with stock halogen bulbs, or try LED or HID replacements?
I'm trying to stay with stock bulbs, and I used this plug-in relay kit off eBay:
relay kit
I'm happy with it, so far.
Upcoming TRS Events
Featured Ranger Based Vehicle
