Arkansas ranger owner.
Featured Build Threads
The 4.6 is out. Not losing my AC. Onto a 2.3 SVO rotating assembly n/a. Maybe a 50 shot on it. 😃 😀 😄
I've gotta find a lower mile M5R1. I got a piece of scyro ring in the oil when I drained it. Bummer. The slave is binding after a long drive at interstate speeds. A 4.6 is OUT. Not losing my AC for no amount of zoom....... Turns out they ain't a SBC. HUGE. So. It SVO 2.3 I guess. I looked at every avaliable option and it looks like the best option.
On the turbo 2.3L thing if you are wanting to keep most of the stock engine or engine operating system from your '95 the only parts you would want to use would be the pistons and rods (rods don't matter but they're attached to the pistons...). It would be a pain to get the older engine to work with the newer crank sensor and cam sensor not to mention the newer heads flow better... there's ways to do it but not to much gain... there were a lot of little changes on the Lima's over the years...
FWIW on my '97 I want to put a mild turbo on it but probably limit to about 5psi with likely one size bigger injector to help out, mainly want mileage since it's my daily driver just need a little more go...
Also depending on how handy you are rebuilding an M5OD by just throwing bearings and synchro's in it isn't a huge job, if you dedicate the weekend to it it could be done...
I've had a turbo busa. I've been thru a 03 turbo beetle. Good car. 2012 Nissan juke. Crap transmission good motor, They all shared one common thing. Way more maintenance and dealing with the heat they produce. Complexities.
I'm using my 97 block. I want a bullet proof rotating assembly. It allows me to do whatever after that's solid.
Currently it's a 95 2300 Mazda head on a 97 block. Even now with high mileage it's got good power.
I'll keep this transmission. Time is the issue right now for me. I can throw in another one in an evening and be back on the road.
It's time to be bowhunting or fishing in Arkansas. The heat finally broke here. It's glorious. Now some rain.
Yeah, 55 days at 100°+ and 33 consecutive is no joke.
That's reasonable, with the stock Turbo forged pistons and everything else stock apparently you don't run into a weak point until around 300hp or something... I leave my '90 at around 14psi so it's maybe 200hp...
200 hp ain't no joke. I've known folks with 400+ turbo busas out of 1340ccs. You start dipping into over 15 psi regularly your fueling has to be bullet proof or you know what happens. Evidently the ECM on these motors are wide open and very tunable. I plan to investigate this farther.
Right now it's clutch time. It's freaking hot again today
That sucked
Dry front and back.
Offending part.
I knew there was a transmission under that crap. What a mess to clean up.
Gave my drive line the black treatment too. Looks👍
The rust converter stuff is too awesome.
Before. Waiting for parts. Clean clean clean. I've got a film of s@#× under the cab from a leaking rear that wasn't cleaned up.
On the road again. Nice clutch again. Was crap for some time.
Dump run. All 👍 onward and upward.
Drove possibly 250 miles? Started stumbling on me on a short trip. A lot of missing coolant. Filled it up. White cloud. Ha. I hope it's just the head. I still have 160 psi on 3 cylinders. The one burning coolant was of course way high. I've got it to the head already. Ill hopefully see it easily. I got an unknown engine. If my block is ok I want to just swap a head on. I'm lazy. Was nice to drive it again. Rode and drove really well.
almost always a crack between the valves in the head so yeah I think you're on the right track.
Looked like 3 was getting some coolant too. The head is toast. Valves sunk. Some hot looking exhaust valves. New injectors will be a must. Nearly 230k on it. I could not see anything obvious.
This was cleaned up.
Little scratchy in the back of 3. Im still getting near 160 outta that hole ?? What are the chances the block is cracked? I may swap it out for now. I dunno yet. I hate to put a head on and find the block cracked. Number 2 was dry and had low compression...the exhaust valve was toast on that chamber. You could tell exactly where the pistons were.
Double posted on me. Anyone??
Event Coverage
Featured Ranger Based Vehicle
