Aluminum Radiator Help
DeadEye200321
Forum Member
💻 TRS Socials
Arizona
AZ - USA
Vehicle
Drive
4" Super Lift
33"
Hello!
I just had the plastic reservoir portion of my radiator crack and start leaking and I need to get a new one. Only problem is I have no idea where to begin to look as I always seem to have trouble finding the correct part for my ranger. I have a 2004 manual Ford Ranger XLT FX4 and all the radiators I seem to look up have a trans cooler, I do not need a trans cooler as my truck is a manual and the current radiator installed does not have ports for a trans cooler. I was wondering if anyone had done and aluminum radiator swap and if they just didn't use the trans cooler ports or if they bought one specifically without one. If anyone has done this could you please provide me with a link to the aluminum radiator you bought? Also, if you did do the aluminum radiator swap, was there still room for the mechanical fan or did you need to swap to an electric fan? Please let me know if you guys have the answers, thank you!
Can't help with the all-aluminum part, but it's pretty common to use a radiator with the trans cooler inside for a manual. Just leave the little plastic plugs in the ports.
So, the factory builds the manual transmission trucks with a radiator that doesn’t have a transmission cooler. Saves them a few bucks.
The aftermarket parts world sees no reason to make and stock two different versions of essentially the same thing. So pretty much all you find for aftermarket replacement parts is the radiators with the transmission cooler. You just don’t hook it up to anything in a manual transmission truck. Doesn’t hurt anything. I’m a little particular so I cap off the ports usually just in case I would ever have to swap it into one of my automatics, but it’s really not necessary.
Yeah, that, just make sure it's for the correct engine size (not sure that matters after a certain point, the older ones the upper and lower hoses switched sizes or angles between the 4 cylinder and V6)
Hello!
The aftermarket world only makes radiators with the transmission cooler in them. If you find a radiator for a manual, you found a rare unicorn.
You can either leave the ports plugged off or use them for an engine oil cooler, if you are feeling ambitious. If you do decide to go that route, make sure the sandwich plate has a thermostat in it. It is possible to over cool an engine. So, you don't want the cooler cooling the oil until it is at about operating temperature.
As far as an all aluminum radiator, some have done them. When mine finally starts to fail, I will be looking into getting one. Just make sure the radiator is the right one for your engine. As some have noted, the upper and lower ports are different from engine to engine. If you can find one with a double row or triple row core, even better.
Being that you live in Arizona, the extra cooling capacity of a muli-row radiator would probably be beneficial, especially if you like to take excursions up into the mountains. The thermostat will make sure the coolant doesn't get too cool.
Will having a multi-row radiator or having a radiator with the trans cooler with it leave room for the stock mechanical fan or will I have to convert to an electric fan?
Yes, fan should be fine, but if you get a thicker radiator, you will need the appropriate fan shroud for that radiator. Trans cooler in the radiator has zero effect on the size of the radiator.
So I would need to get an aftermarket fan shroud then?
Only if you get a thicker radiator than what you have. And you wouldn’t have to go aftermarket, you could get a junkyard one. Looks like there’s only one radiator listed for your year and engine size, so if you just get a standard replacement, your shroud works.
If you try to do something like the 00 Explorer 5.0 rad and make it work (it will physically fit but it’s twice as thick as stock for yours), you will need a fan shroud for that radiator and you may or may not have to do something about the radiator hoses since the ports on the Explorer rad may not match yours and your shroud will not bolt up. I have the Explorer rad in my 00 because I did the 5.0 swap, so I used the shroud for the thicker radiator because the Ranger shroud won’t fit. If I think about it and the weather isn’t too bad tomorrow I can get a pic, I have both here.
So would something like these, fit in my ranger with stock mounting and require modification to the fan shroud or fan or would I be pretty much good to go?
Aluminum Rad 1
Aluminum Rad 2
Event Coverage
TRS Merch
