Air chisel works great and fairly quick. Plus it’ll vibrate all the rust off the frame
What’s your plans with this build?
It’s a BWs366 66/73What's the sizing on that whistlin' air forcifier of yours?
I’m really no expert, this is my first full build and my first attempt at a LS turbo but I’ve read a ton and Richard Holdener has put out so much info I feel like one lol. For that power goal I would stick with a single. I’m only looking for 450-500whp and the s366 is good for about 650. A VS78/75 would get you there.Either of you works lol thanks.
But right on. I'm trying to figure out what size I want to go with right now.. but I'll be running twins so apples/oranges.
Gonna be a bone stock 4.8 in a majority dragstrip use car, trans is rated for 900hp so I'd LIKE to end up with 7-800 but obviously being bone stock I'm going to be limited by my heads/cam.
Once I get the car running on whatever setup I end up with the plan is to start amassing parts to build an aluminum block flat plane crank 4.8.. might have to be a 5.3 though.
That engine bay is looking awesome. Did you plumb the wastegate dump back into the downpipe for inspection purposes?
