Today's the day for the cam synchronizer.
I'm having trouble understanding what's going on back there. Upper intake is off. Engine is (hopefully) at #1 compression TDC. Cam sync bolt is loose.
Is this thing supposed to spin, or start lifting out, or something? It doesn't move at all, and the bolt is directly underneath the plug. I assume it's just stuck? But I don't want to snap the sensor off, and I can't see a goddamned thing.
Honestly not sure how you're supposed to align the new one. Apparently '95 doesn't take the alignment tool, it has this little window. But since it's impossible to see behind the engine, I don't see how I can look through the window.
This dude is installing the window sync, but he has the engine out. Service manual talks about using a voltmeter for final alignment, but you're still supposed to use the window first.
EDIT: Plug snapped off the sensor. Still zero movement. Whoever designed this thing is a toolbox.
EDIT 2: Suggestions from around the web include "hit it from below or through the passenger wheel well", which is... not a thing. Maybe if it would already rotate so the connector was facing further aft/towards the passenger side? And "slide hammer up off the sensor screw-holes", which I also don't see happening. Even with the trans crossmember nuts off and the transfer case jacked up into the bottom of the body, the slide hammer won't clear the cowl.
I have been prying and beating on this fucking thing for an hour, and it has not moved half a mm.
EDIT: It did move half a mm, right before continued attempts to pry and slide-hammer shattered the top of the housing. I really don't see how I could possibly get this thing out even if I had the engine out, and I almost can't belive it's in such a dumbshit spot.
